Cheap chinese z-wave products
Re: Cheap chinese z-wave products
Does this mean that you’r not able to change “Ambient Illumination Lux Level Report” parameter 9 from
http://www.pepper1.net/zwavedb/device/894 as well?
I can change it, but it doesn't send anything to my system
http://domo-attitude.fr
I guess that because the sensor is long time in sleeping modus, you will have to wait (untill the sensor is awake) before your update of values is operational in the sensor. Update now and wait and see later (eg tomorrow) that your change has become effective.geezerrr wrote:Does this mean that you’r not able to change “Ambient Illumination Lux Level Report” parameter 9 from
Or use the trick mentioned above.
There are many happy buyers; over 90 people (and the numbers are rising) and I do not see complaints @lost wrote:Welcome in the happy Neo buyers club...
https://www.aliexpress.com/item/NEO-COO ... 49261.html
Не отправленные с моего BlackBerry через Tapatalk
On my side, this is the parameter 6, re-trigger interval, that cannot be changed.geezerrr wrote:Can you try to change the report state (lux) to anytime else then the default 100?deennoo wrote:just get a wall plug and a pir, no probleme to add them with domoticz last stable + gen5 w090
Because I'm unable to change it.
Thnx in advance
It's at 8s, wanting to set it at 30s or a minute, with param 2 (on/off duration) set to 120s (this setup worked, as well as sentivity change, param 1).
I already included latest config patches (there is a quite recent one that's not in current domoticz stable)
The module finally works, but looks quite problematic on the inclusion side as well as for configuration.
- Domoticz version: 2020.2
Today I received the Neo coolcam wall plug. Including was easy in domoticz. Just set domoticz to learn mode en insert de wall plug.
The plug wil be automaticlly added and will show in the hardware list.
What I noticed is that I need to use a F, CEE 7/4 Schuko plug to switch a device. I first used a flat "euro" plug and it seems that the two pins are sometimes to small te make a good connection with the inside of the Neo Coolcam wall plug. So be aware.
Price drop for the plug:
http://s.aliexpress.com/ZFnEJvyI
- Domoticz version: V3.5613
Re: RE: Re: Cheap chinese z-wave products
Hmmm, two questions about the wall plug. Have a few now and are working great.LouiS22 wrote:Have you really tried it? You have to push three times quickly. If you hear any clicking noise then it's working. Maybe you should try it with another socket, etc.zalsson wrote:so, now one of my power plugs are deadStopped responding, no reaction when i push the green button. Nothing.... quailty haha
However:
-) Two new plugs did not survive being connected to my fridge plug. Was grounded, so don't really know what the problem is. But, cannot find a fuse. There isn't one is there...
-) The plugs do result in a few devices, sometimes a kwh meter, besides Watt. But this one is so not stable. Any idea how I can improve this device?
Verstuurd vanaf mijn SM-G920F met Tapatalk
The one that broke for me is the only one that was used with ground pin connected
Skickat från min A0001 via Tapatalk
The wait is for in wall switches... I have two doorsensors and a wall plug. I think price quality is very good.
Me happy buyer
Me happy buyer
- LouiS22
My second door sensor was somewhat damaged (actually the reed tube was broken), but I fixed it and it's working. Only it has a loud clicking noise upon contacting/breaking with the magnet. It's somehat funny cause this sensor is placed onto the toilet door. No more sneaking quietly into the loo
Received two wall plugs and they work wel! Even works with Eneco toon though without energy readings. In domoticz there is kWh but I get strange results...
Anyone knows why?
Sent from my Nexus 6P using Tapatalk
Anyone knows why?
- sincze
- Domoticz version: 2024.4
Great to read the NEO hardware experiences. The store owner is probably reading this forum as well and keeps increasing the price. Now at Fibaro pricing level of §55.domcao wrote:There are many happy buyers; over 90 people (and the numbers are rising) and I do not see complaints @lost wrote:Welcome in the happy Neo buyers club...
That is twice the 11-11 sales price so probably increasing his margin a bit
Sent from my SM-G925F using Tapatalk
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Well I got mine from here €32,-
Home Automation Z wave Sensor Smart Home EU Power Plug Compatible with Z-wave 300 series and 500 series
http://s.aliexpress.com/fmY3AZbq
(from AliExpress Android)
- sincze
Yes keep a look out for different sellers always a good ideakurniawan77 wrote:Well I got mine from here €32,-
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Some of the sellers are different, with the same post address
and they rotate the 'sale'
- sincze
Wow that I did not know. Good tip will look at that from now on.trixwood wrote:Some of the sellers are different, with the same post addressand they rotate the 'sale'
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Also buy with the Aliexpress app. It had special mobile only discounts.
But indeed prices gone up again. With Christmas I saw one for 26 euro wall plug.
The price goes up and down like I normally do on aliexpress.
I'll post it tomorrow hereJustinb81 wrote:May I test your XML as well?nieass4 wrote:I just created the xml file, I'll test it out and submit it to openzwave githubJustinb81 wrote:
I have the AS-AB01Z siren as well, and studying on how to create the XML file... just not studying hard enough..
All info needed is here: http://products.z-wavealliance.org/products/1962
Only the Device ID is wrong, that should be
Neo CoolCam Battery Powered Siren/Doorbell: type=0003, id=1088
I am forced by my wife to stay the Christmas holidays with the family in a vacation park, so maybe I will give it a go when there.
Verstuurd vanaf mijn SM-N9005 met Tapatalk
