Eurotronics Stella Z will not include
hieronymus
I already have search on the internet for include my stella z thermostate unit to include in my z-wave network
I use a raspberry pi with zwave module on it.
I use the newest image off domoticz, no update required.
Fibaro relay en motion sensor i can add an control it but stella will not recognize.
Does somebody can help me to fix this problem
Also i have a problem with fibaro smoke sensor that it will not be active true the switches
- blackdog65
Re: Eurotronics Stella Z will not include
As an ex-stellaz user, I can say it is simple
1) exclude the stellaz
2) include the stellaz
3) exclude again as it didn't include properly
4) Keep repeating steps 1 to 3
Eventually it will include, it may sleep and never wake, it may eat batteries... I gave up on them in the end.
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
hieronymus
Hmz okay this is was not what i hoping for.
What kind off thermostate do you use?
jannl
- Domoticz version: 2026.1.x
Except for the batteries that remain only about 2 or 3 months, I never had any problem with the one stella z I use.
hieronymus
batterij is no issue for me only that i can not include the stella z unit :s
- Westcott
Try putting Domoticz into Setup->Hardware->OpenZwave Setup button->Node management->Include node
Then hold the StellaZ button down for a moment until the steady green light shows.
See if the Include node dialogue shows the StellaZ.
If not, and still in Domoticz include mode, hold the button down for at least 15 seconds, ignoring any red or green lights.
That's how I got mine to include, the first time I tried.
hieronymus
Both steps i have done without any include unit
jannl
Not sure if the accept new hardware setting in Domoticz must be set on.
- gizmocuz
Try also to exclude first... maybe the module was tested
Also had a problem including this module, but it worked in the end.
First Domoticz in include mode, and then setting the stellaz in include mode
(Accept new hardware is done automatically)
- blackdog65
As I said in my post and Gizmocuz too, EXCLUSION 1st is the most critical step. I do it by habit now with ALL z-wave products. All of which work very nicely for me with the exception of the StellaZ.
I now use the EQ3 Max! system for heating control (rads and stats) with a fibaro dual relay controlling heating and hot water. There is only limited support for EQ3 Max! in Domoticz but it works very well as a stand alone system.
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
hieronymus
If i use the exlusion function in domoticz, there's also nothing happening
If i exclude true vera edge it's say exclude device proberly but nothing happend on domoticz :S
- blackdog65
Do you have other z-wave devices that work ok?
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
hieronymus
the follow unit are include in the network
fibaro relay switch 5x
fibaro motion sensor 3x
fibarp smoke sensor 3x
hieronymus
I got 1 add to my system.
But i have 3 other stella witch i like to add.
But when i add them them same way i did with the first nothing is happening.
On stella the green led is on for 2 sec means it's enter zwave network.
With openremote i can exclude all device by hit 1 time on button.
1 i have include the same, but other seems not regornice
- Westcott
The green led for 2 secs just means that the StellaZ is awake.
See my post above.
See my post above.
hieronymus
Well finally i got include them but nothing will happen when I change the setting.
Look at the forum but find no sollution for this.
Any one has them work correctly?
jannl
I use 1 stellaz and it basically works without problems. I use a lua script to open and close the valve depending on the temperature. I included it from within Domoticz.
