Kodi add-on to control Domoticz
pvm
- Domoticz version: 4.10538
Re: Kodi add-on to control Domoticz
Is this add-on related to the Kodi Media Server hardware type added to Domoticz recently??
I activated that but it does not show anything
Raspberry Piet
pvm wrote:Is this add-on related to the Kodi Media Server hardware type added to Domoticz recently??
No it is not related.
I also noticed this new functionality within Domoticz.
It automaticaly makes this switch:
Maybe start a new thread about this new promising functionality?
pvm
Sorry for using this topic, made new one in http://www.domoticz.com/forum/viewtopic.php?f=28&t=7098
- sincze
- Domoticz version: 2024.4
Looks very nice version 0.0.6. Thanks for the instructions via:
https://www.chopperrob.nl/xbmc-add-ons/ ... -from-kodi
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
- Egregius
- Domoticz version: v2024.7
Nice thing from chopperrob
Altered one line in default.py do:
Added the last or statement because dimmers didn't function.
if json_object["result"][i]["Status"] == "On" or json_object["result"][i]["Status"] == "Open" or json_object["result"][i]["Status"] == "All On" or json_object["result"][i]["Status"][:3] == "Set": -
mrjem
Hello
I tryed to install this addom on my Windows 7 pc with te latest version of kodi.
Script faild it says
i try to install version 006 but it wont work
Whats wrong ??
Whats wrong ??
- Egregius
Does the kodi.log file gives a clue?
Marcinek
Where can I find documentation for this add-on
kniazio
- Domoticz version: 3.7243
I have version 3.6154 domoticz
Plugin seems to see my Domoticz.
He sees room plan.
He can not see devices
He sees room plan.
kniazio
Can you share this add-on?
MikeF
- Domoticz version: V2022.2
I'm getting '404 Not Found' on @Chopper-Rob's url - is this no longer available?
MikeF
Just found it here: viewtopic.php?t=11576 - thanks @egregius - and got it working. Nice!
(I'm using osmc on a RPi 3)
- Denny64
- Domoticz version: 2023.1
Hi MikeF.
I suppose you're looking for this: https://github.com/h4wkmoon/xbmc-domoti ... master.zip
SeeU
SeeU
kniazio
This plugin sees my devices but does not launch them
kniazio
I think this is a problem hereDenny64 wrote:Hi MikeF.
SeeU
# Function to send commands to domoticz.
# It handles
# switches
# dimmer
# scenes & groups
def sendcmd(args):
opt=""
for val in args:
if opt!="":
opt=opt+"&"
opt=opt+val+"="+args[val]
#http://www.bbrose.net/domoticz//json.htm?cmd=On&type=command¶m=switchlight&idx=22
#~ log("Sending "+cmd+" to Switch "+str(switchid), xbmc.LOGNOTICE)
#~ thisurl=__rooturl__+"/json.htm?type=command¶m="+itemtype+"&idx="+str(switchid)+"&switchcmd="+cmd+"&level="+str(level)
thisurl=__rooturl__+"/json.htm?"+opt
log ("URL is "+thisurl , xbmc.LOGNOTICE)
xbmc.executebuiltin( "ActivateWindow(busydialog)" )
try:
pagehandle = urllib2.urlopen(thisurl)
html = pagehandle.read()
pagehandle.close()
except:
html="Error !!"
xbmc.executebuiltin( "Dialog.Close(busydialog)" )
log(html, xbmc.LOGERROR)
xbmc.sleep(2)Code: Select all
#http://www.bbrose.net/domoticz//json.htm?cmd=On&type=command¶m=switchlight&idx=22Code: Select all
json.htm?type=command¶m=switchlight&idx=18&switchcmd=On&level=0-
Chopper_Rob
Hi guys,
If anyone is still looking for this add-on.
You can find it here:
https://www.dropbox.com/s/damik7spatoms ... l.zip?dl=0
kniazio
But this plugin does not work for me.
It does not show my devices.
I have yet another plugin.
Very nice looks, shows my devices but they do not switch
https://github.com/h4wkmoon/xbmc-domoticz
Plugin works but only in Scenes.
What to do to work on Switches?
- IMG_20170422_172117_rs.jpg (109.12 KiB) Viewed 4932 times
mrjulien
very nice plugins but don't work at home...i leave an issue on github.
i'm impatient to use it !
in fact, project is over and need some improvement. i'll try to create a fork
