Amazon Echo to Domoticz Bridge: switches, sensors & more
fergalom
Re: Amazon Echo to Domoticz Bridge: switches, sensors & more
nothing showing in the logs so I guess not, am using eu-west and english uk so may try switching.
fergalom
Switched to English U.S, and my lambda is in N.Virginia and worked first time!Madgeni wrote:hmm is the skill firing the lamdba - can you check the logs?
I think there's some general problems with skills linking to lambda functions. My skill is using English U.S, and my lambda is in N.Virginia if that helps.
Thanks!!
Madgeni
Perfect! That's really good - welcome
- heggink
- Domoticz version: 12451
So if i wanted UK english, is that currently an issue?
Verstuurd vanaf mijn HUAWEI NXT-L29 met Tapatalk
DASHTICZ 🙃
P1 meter & solar panel
DASHTICZ 🙃
Madgeni
well, i believe nigels0 has it working in Ireland with English UK but i have the US English one, and it makes no difference to the usage to me. It understands my commands just fine. Latency is <1sec for discovery, <0.5s for interactions. Quicker than my direct Hue integrated lights for sure.
- heggink
My accent is British
️Verstuurd vanaf mijn HUAWEI NXT-L29 met Tapatalk
DASHTICZ 🙃
DASHTICZ 🙃
Madgeni
i am very british
- heggink
And can talk to it successfully?
DASHTICZ 🙃
DASHTICZ 🙃
Madgeni
yes
fergalom
Thanks, this works a treat.
Couple of feedback items:
- 1. On/off work perfect, dimming does not work well, i.e. asking for 10% will result in 35% for example
2. Thermostat - works perfect for me - only thing is the Alexa confirmation is "Setting Thermostat to unknown temperature" i.e. Alexa does not repeat back the setpoint temperature - not a big deal but would be nice.
3. Temperature devices - what is the correct syntax for asking Alexa the temperature?
4. Are multi-selector switches supported?
Madgeni
1. Argh! This seems to be a very strange issue, where it seems fine for some people, and wrong for others. What type of Dimmers do you have out of interest?
2. I'll take a look - not sure what happens to the payload, as the integer seems to be there, so not sure why Alexa doesn't interpret it
3. I'm afraid that currently Alexa doesn't support asking via the Smart Home Skill. As soon as it does, i'll implement it. The only way to get this would be to rebuild it as a Custom skill (Alexa, ask 'Home' what the temperature is in the front room etc etc) - but would be a piece of work to do this. I'm loathe to whilst this is allegedly on Alexa's roadmap for Smart Home
4. Can you give me a couple of user stories for multi-selector switches to work with?
nigels0
- Domoticz version: 3.8153
Yes, all the above is true. I've built 2 of these and both worked no problem with the EU-West and UK English parameters. Latency is about the same (it generally switches before I get the 'OK')Madgeni wrote:well, i believe nigels0 has it working in Ireland with English UK but i have the US English one, and it makes no difference to the usage to me. It understands my commands just fine. Latency is <1sec for discovery, <0.5s for interactions. Quicker than my direct Hue integrated lights for sure.
fergalom
They are all dummy dimmers - Type: Light/switch - Switch: DimmerMadgeni wrote:1. Argh! This seems to be a very strange issue, where it seems fine for some people, and wrong for others. What type of Dimmers do you have out of interest?
Using multi-selectors to enable various airplay speakers around the house, quickly set heating modes, select & play some radio channels.
Interestingly if you ask alexa to set a multi-selector switch to a percentage, it works sort of (the dimming issue skews it).
Bororo
Just a curious question for Echo/dot owners: Can this device communicate in English, but use metric system? (I don't want to receive answers in miles, pounds or lbs, but metres, kg, etc.)
- StanHD
Re: RE: Re: Amazon Echo to Domoticz Bridge: switches, sensors & more
Yes I have UK Echo Dots and there is a setting for metric temperature and distance units.Bororo wrote:Just a curious question for Echo/dot owners: Can this device communicate in English, but use metric system? (I don't want to receive answers in miles, pounds or lbs, but metres, kg, etc.)
Python:- Broadlink RM2, Sonos
- l0gic
- Domoticz version: Latest
Got to the bottom of this. I had a defined room that I hadn't populated with any units.l0gic wrote:Hi,
just updated to latest code and I'm getting the following in the lambda logs
This seems to be while running a discovery.Code: Select all
2016-11-29T10:48:53.222Z 691f17c3-b621-11e6-a006-c9681d09aea6 TypeError: Cannot read property 'length' of undefined at /var/task/domapi.js:401:42
If I understand it correctly, is should also discover temperature set point units, these do not appear in discovered devices but I guess that could well be down to the code not completing.
Control of the discovered units seems to be ok still.
All the best
Kevin
Worth bearing in mind when doing a discovery.
All the best
Kevin
Non credus crepitus
Madgeni
Yep, it's a well known 'feature' - basically i do no error handling on there being no room plans, or no devices IN room plans. I'll fix it shortly
- heggink
Does amazon charge anything for the Lambda function?
DASHTICZ 🙃
DASHTICZ 🙃
Madgeni
No, they have a free tier, which is huge for this purpose:
1M free requests per month and 400,000 GB-seconds of compute time per month
https://aws.amazon.com/lambda/pricing/
- heggink
Good to know. If I get an invalid character error, any ideas on where to look for a solution? Followed your doc (only thing missing seemed to be listing the endpoint).
DASHTICZ 🙃
DASHTICZ 🙃
