Amazon Echo to Domoticz Bridge: switches, sensors & more
Alexa, Google Home and Siri
fergalom
Re: Amazon Echo to Domoticz Bridge: switches, sensors & more
Post by fergalom »
nothing showing in the logs so I guess not, am using eu-west and english uk so may try switching.
fergalom
Post by fergalom »
Madgeni wrote:hmm is the skill firing the lamdba - can you check the logs?
I think there's some general problems with skills linking to lambda functions. My skill is using English U.S, and my lambda is in N.Virginia if that helps.
Switched to English U.S, and my lambda is in N.Virginia and worked first time!
Thanks!!
Madgeni
Post by Madgeni »
Perfect! That's really good - welcome :)
heggink
Domoticz version: 12451
Post by heggink »
So if i wanted UK english, is that currently an issue?
Verstuurd vanaf mijn HUAWEI NXT-L29 met Tapatalk
DASHTICZ 🙃
P1 meter & solar panel
Madgeni
Post by Madgeni »
well, i believe nigels0 has it working in Ireland with English UK but i have the US English one, and it makes no difference to the usage to me. It understands my commands just fine. Latency is <1sec for discovery, <0.5s for interactions. Quicker than my direct Hue integrated lights for sure.
heggink
Post by heggink »
My accent is British
DASHTICZ 🙃
Madgeni
Post by Madgeni »
i am very british :)
heggink
Post by heggink »
And can talk to it successfully?
DASHTICZ 🙃
Madgeni
Post by Madgeni »
yes
fergalom
Post by fergalom »
Thanks, this works a treat.
Couple of feedback items:
  • 1. On/off work perfect, dimming does not work well, i.e. asking for 10% will result in 35% for example
    2. Thermostat - works perfect for me - only thing is the Alexa confirmation is "Setting Thermostat to unknown temperature" i.e. Alexa does not repeat back the setpoint temperature - not a big deal but would be nice.
    3. Temperature devices - what is the correct syntax for asking Alexa the temperature?
    4. Are multi-selector switches supported?
Madgeni
Post by Madgeni »
1. Argh! This seems to be a very strange issue, where it seems fine for some people, and wrong for others. What type of Dimmers do you have out of interest?
2. I'll take a look - not sure what happens to the payload, as the integer seems to be there, so not sure why Alexa doesn't interpret it
3. I'm afraid that currently Alexa doesn't support asking via the Smart Home Skill. As soon as it does, i'll implement it. The only way to get this would be to rebuild it as a Custom skill (Alexa, ask 'Home' what the temperature is in the front room etc etc) - but would be a piece of work to do this. I'm loathe to whilst this is allegedly on Alexa's roadmap for Smart Home
4. Can you give me a couple of user stories for multi-selector switches to work with?
nigels0
Domoticz version: 3.8153
Post by nigels0 »
Madgeni wrote:well, i believe nigels0 has it working in Ireland with English UK but i have the US English one, and it makes no difference to the usage to me. It understands my commands just fine. Latency is <1sec for discovery, <0.5s for interactions. Quicker than my direct Hue integrated lights for sure.
Yes, all the above is true. I've built 2 of these and both worked no problem with the EU-West and UK English parameters. Latency is about the same (it generally switches before I get the 'OK')
fergalom
Post by fergalom »
Madgeni wrote:1. Argh! This seems to be a very strange issue, where it seems fine for some people, and wrong for others. What type of Dimmers do you have out of interest?
They are all dummy dimmers - Type: Light/switch - Switch: Dimmer
Using multi-selectors to enable various airplay speakers around the house, quickly set heating modes, select & play some radio channels.
Interestingly if you ask alexa to set a multi-selector switch to a percentage, it works sort of (the dimming issue skews it).
Bororo
Post by Bororo »
Just a curious question for Echo/dot owners: Can this device communicate in English, but use metric system? (I don't want to receive answers in miles, pounds or lbs, but metres, kg, etc.)
StanHD
Re: RE: Re: Amazon Echo to Domoticz Bridge: switches, sensors & more
Post by StanHD »
Bororo wrote:Just a curious question for Echo/dot owners: Can this device communicate in English, but use metric system? (I don't want to receive answers in miles, pounds or lbs, but metres, kg, etc.)
Yes I have UK Echo Dots and there is a setting for metric temperature and distance units.
Python:- Broadlink RM2, Sonos
l0gic
Domoticz version: Latest
Post by l0gic »
l0gic wrote:Hi,
just updated to latest code and I'm getting the following in the lambda logs
2016-11-29T10:48:53.222Z	691f17c3-b621-11e6-a006-c9681d09aea6	TypeError: Cannot read property 'length' of undefined
at /var/task/domapi.js:401:42
This seems to be while running a discovery.
If I understand it correctly, is should also discover temperature set point units, these do not appear in discovered devices but I guess that could well be down to the code not completing.
Control of the discovered units seems to be ok still.
All the best
Kevin
Got to the bottom of this. I had a defined room that I hadn't populated with any units.
Worth bearing in mind when doing a discovery.
All the best
Kevin
Non credus crepitus
Madgeni
Post by Madgeni »
Yep, it's a well known 'feature' - basically i do no error handling on there being no room plans, or no devices IN room plans. I'll fix it shortly
heggink
Post by heggink »
Does amazon charge anything for the Lambda function?
DASHTICZ 🙃
Madgeni
Post by Madgeni »
No, they have a free tier, which is huge for this purpose:
1M free requests per month and 400,000 GB-seconds of compute time per month
https://aws.amazon.com/lambda/pricing/
heggink
Post by heggink »
Good to know. If I get an invalid character error, any ideas on where to look for a solution? Followed your doc (only thing missing seemed to be listing the endpoint).
DASHTICZ 🙃
