corbin
Post by corbin »
I'm not sure if you are asking if Domoticz updates faster than the Xiaomi gateway? As that would be impossible since they go through Zigbee to the gateway first, then onto WiFi to my Domoticz server. In practice Domoticz is updated almost instantly.
At about $10-15 for a battery powered motion sensor, it is cheaper and smaller than the motion sensors I've made.
corbin
Post by corbin »
I want to add in the Xiaomi switches as well, but they are not on/off switches like a wall light switch, they are toggle switches and I'm not sure how to set them up. Is there any similar switches already working with Domoticz?
deennoo
Post by deennoo »
yeap push on switch device
http://domo-attitude.fr
deennoo
Post by deennoo »
corbin wrote:Domoticz is updated almost instantly.
Ok that the key, using xiaomi pir for autolight means less than 500ms to light up
deennoo
Post by deennoo »
corbin wrote:I want to add in the Xiaomi switches as well, but they are not on/off switches like a wall light switch, they are toggle switches and I'm not sure how to set them up. Is there any similar switches already working with Domoticz?
On / off can be choose if
When recieving swith info you chech state off the on/off domoticz switch and toggle it
corbin
Post by corbin »
ok thanks, will make it a 'push on' button, and have it stay on for a couple of seconds for single click, 10 seconds for long click, and something else for double click
corbin
Post by corbin »
Wireless switch and door sensors have been added:
deennoo
Post by deennoo »
corbin wrote:Wireless switch and door sensors have been added:
Yes ! That is good !
Have you a cube ?
Have you a wall switch (not sure it works with zigbee, if it's a zigbee it have to extend zigbee range)
Have you a temp sensor ?/
Derik
Post by Derik »
Dear All.
What hardware do i need for sure...
What is best set to start?
And... Is there a set incl a EU plug perhaps?
Edit"
Sorry
GREAT work guys...
Derik
Post by Derik »
And does the Xiaomi act like Zwave?
Give a status update ...?
deennoo
Post by deennoo »
Xiaomi use zigbee with xiaomi spec who made it run only with xiaomi products.
But base is zigbee.
All about zigbee : http://www.zigbee.org
deennoo
Post by deennoo »
[quote="Derik]
.[/quote]
Chinise plug with EU adapter, No CE certificat.
Once again have a look to your favorite google, and aliexpress.
corbin
Post by corbin »
Have you a cube ?
I have none of those, but should be able to implement them ok. Also have some xiaomi ZigBee power plugs on order
Derik
Post by Derik »
Are there some eu plugs or where do live?
corbin
Post by corbin »
I live in Australia, where the plug works with Chinese plug but just upside down.
I don't think there is an EU plug for the current range. Maybe this old model had it though http://www.gearbest.com/cables-connecto ... 68522.html
Also, I don't know if there is a way to control the smart plug as yet, maybe only read the status. I hope it can be controlled of course and will try when my plugs arrive.
deennoo
Post by deennoo »
corbin wrote:I live in Australia, where the plug works with Chinese plug but just upside down.
as usual for australian thing seen from europe ! :D lol
corbin wrote:I don't think there is an EU plug for the current range. Maybe this old model had it though http://www.gearbest.com/cables-connecto ... 68522.html
as i already says to derick who doesn't read my answer, aliexpress sellers ask you which plug adapter you need if you don't ask it on order, and send it for free. if you need to buy one : http://www.gearbest.com/plugs-sockets/p ... d=10117050 is perfect and cheap
corbin wrote:Also, I don't know if there is a way to control the smart plug as yet, maybe only read the status. I hope it can be controlled of course and will try when my plugs arrive.
If they are on a real zigbee that a good news, because they can be use as zigbee network relay to extend range.
One question stay : How many device gateway can accept ?
On my case i need more than 23 devices (pir/temp/door sensor) + 20 switchs + 20 wallplug to remove all or meanly of my 433mhz devices.
Have you put ability to add 2 or 3 gateway if one can't support more than 20 as i read on a french home automation forum ?
Any way to drive gateway build in led ?
corbin
Post by corbin »
Haha!
I wouldn't run the plug through an adapter though, makes it a bit bulky.
Not sure about the device limit, if you hit it I will try to make it work with 2 or 3 gateways (it might already work just needs to be tested)
Will look into controlling the gateway LED.
jjnj
Post by jjnj »
It would be great if the Xiaomi Mi Smart Home All-In-One Media Control Center could be intergrated too.
It's a really cheap IR blaster http://xiaomi-mi.com/smart-home/xiaomi- ... ol-center/
corbin
Post by corbin »
jjnj wrote:It would be great if the Xiaomi Mi Smart Home All-In-One Media Control Center could be intergrated too.
one day at a time sweet jesus
deennoo
Post by deennoo »
And what about rice cooker ? Air purifer ? Xiaomi pen ?xiaomi cable box ? Lol
