A lot of times, the temperature sensor is not working quite well.. It seems like it's just dies when I set the Thermostat to 'away' (in graph below, this would be around 22:00) and it doesn't wake up when I set it back to 21 degrees (at 7:30).
- Screen Shot 2016-12-03 at 09.06.38.png (220.08 KiB) Viewed 973 times
Setting the temperature with Domoticz is not a problem.
I tried forcing the update script:
But to no avail.
This script is also present in my crontab:
- Screen Shot 2016-12-03 at 09.10.52.png (51.82 KiB) Viewed 973 times
I already removed all devices, and re-installed them with:
The reading of the temp is working fine in the Honeywell 'Home' app.
Any thoughts? Any logging I could check?
