HEOS by DENON
Sneezydevil
HEOS by DENON
Post by Sneezydevil »
Hey all,
It looks like the HEOS by DENON code made it into Domoticz last night. All you should have to do is add one of your HEOS speakers under hardware. Once one speaker is added all others should be detected automaticly.
There are a few buttons on the left of the remote that are not working yet.
Let me know what you think sofar.
Steven84
Re: HEOS by DENON
Post by Steven84 »
Nice, i only don't see a remote when clicking?
Sneezydevil
Re: HEOS by DENON
There is a remote in the latest code, that should allow you to pause, play, stop, mute etc.
I forgot to update the appcache file, so it might be that.
I created a pull request with a updated appcache file.
If you don't want to wait you can try and update the file yourself its located in the www folder of domoticz and is called html5.appcache.
Change the number at the top from 1298 to 1299.
Steven84
Re: HEOS by DENON
Post by Steven84 »
yes it works!!
This is great. Could you tell me where i can edit the volume level?
I think that it now goes in steps of 5%. I would prefer steps of 2 or 3.
Already search with winscp for the files but unfortunately didn't find.
Sneezydevil
Re: HEOS by DENON
I currently use this (without step), so it indeed defaults to 5.
4.2.8 Volume Up
Command: heos://player/volume_up?pid=player_id&step=step_level
Attribute Description Enumeration
pid Player id returned by 'get_players' or 'get_groups' command N/A
step Player volume step level 1 to 10(default 5)
Response:
      "heos": {
                       "command": " player/ volume_up ",
                       "result": "success",
                       "message": "pid='player_id'&step='step_level'"
If you want to change that, you would have to change:
https://github.com/domoticz/domoticz/bl ... e/HEOS.cpp
You would however have to recompile.
At first I thought 5 would be nice since it was Denons default, but for me it is a bit much aswell.
I will do some testing with different numbers.
Arjay
Domoticz version: v3.5877
Re: HEOS by DENON
Post by Arjay »
Very nice that HEOS also can be used through domoticz! I just added a heos1 in hardware tab and it shows HEOS by DENON and a button setup. This button doesn't function. So I opened the html.appcache file but this starts with 1306 and not 1298. What do I misunderstand? :?
Sneezydevil
Re: HEOS by DENON
Changing the appcache file should not be needed in the recent versions.
Is there no IP field (Below all the hardware) when the hardware is selected?
Arjay
Re: HEOS by DENON
Post by Arjay »
Through a ip network scan I found the IP address of Heos. I added the Heos by filling in this hardware IP field, and now its visible in domoticz /#/hardware with idx23 port 1255. The blue setup button doesn't recognize its being "touched", if there is no <ahref> (html) in the code. :roll:
The other buttons like "create virtual sensors" do recognize when I point them so it's possible to create a virtual sensor.
Sneezydevil
Re: HEOS by DENON
I don't think the setup button should be there at all, since there is nothing to setup other then the ip.
Will add that to my todo list.
Does it working apart from the button doing nothing?
//Edit
You should be able to see the IP in the HEOS app on your phone.
Clemen
Re: HEOS by DENON
Post by Clemen »
I just get this in domoticz log
2016-12-01 17:26:11.959 Error: DENON for HEOS: No players found.
2016-12-01 17:26:13.959 HEOS by DENON: Connected to: 10.200.0.149:1255
And no new devices in device tap
Arjay
Re: HEOS by DENON
Post by Arjay »
I thought I had to setup remote by use of the blue button. Don't know how to control the Heos through Domoticz now. Can't find out how to use this feature :oops: possible to explain me a bit more :?:
Indeed the app shows the same ip as I discoverd through scantool :)
Soulplayer
Re: HEOS by DENON
Post by Soulplayer »
Clemen wrote:I just get this in domoticz log
I've got the same error. It used to work but there was an update a few days ago. I noticed the information was not getting updated anymore so I tried to remove & add them again. But this time it did not work as previously. No Heos switch gets added after installing the "hardware".
2016-12-04 09:48:28.248 HEOS by DENON: Worker started...
2016-12-04 09:48:28.249 Error: DENON for HEOS: No players found.
2016-12-04 09:48:30.249 HEOS by DENON: Connected to: 10.0.1.5:1255
Steven84
Re: HEOS by DENON
Post by Steven84 »
Here the same :-(
Sneezydevil
Re: HEOS by DENON
@Steven84: It used to work, is that correct?
My code hasn't changed so I wonder what is going on. Was it a update to HEOS or Domoticz that made it stop working?
Soulplayer
Re: HEOS by DENON
For me it was an update to heos that made it stop working.
Sneezydevil
Re: HEOS by DENON
I didn't notice myself because first my heating stopped working and then I had a leaking roof so haven't had time to play music. Sorry I missed your first post Soulplayer.
I downloaded the latest CLI specifications (1.373.100) from HEOS, but that still looks the same (bit more information, but the same).
 "heos": {
 "command": "player/get_players",
 "message": ""
 "payload": [
 "name": "'player name 1'",
 "pid": "player id 1'",
 "gid": "group id'",
 "model": "'player model 1'",
 "version": "'player verison 1'"
 "network": "wired"
 "lineout": "level type"
 "control": "control option"
But in the release notes of firmware version 1.382.80, I find the following:
Improved stability with 3rd party control systems
Not sure what that means but it sounds like it could be the problem.
Any of you familiar with telnet?
Clemen
Re: HEOS by DENON
Post by Clemen »
Sneezydevil wrote:I didn't notice myself because first my heating stopped working and then I had a leaking roof so haven't had time to play music. Sorry I missed your first post Soulplayer.
 "heos": {
 "message": ""
 "payload": [
 "gid": "group id'",
 "network": "wired"
indeed familiar with telnet.
Sneezydevil
Re: HEOS by DENON
Clemen wrote:
Sneezydevil wrote:...
Could you try connecting to a speaker, and checking something for me?
telnet 10.200.0.149 1255
When connected issue the command:
heos://player/get_players
That command should return the players in your network, which is for some reason no longer working. If you could let me know the result of that command, that would be awesome. I currently don't have access to my own speakers otherwise I would do it myself.
Sneezydevil
Re: HEOS by DENON
I found what Denon changed and why it is no longer working, created a pull request with a fix.
Clemen
Re: HEOS by DENON
Post by Clemen »
{"heos": {"command": "player/get_players", "result": "success", "message": ""}, "payload": [{"name": "Stue", "pid": -1642968613, "model": "HEOS Link", "version": "1.382.80", "ip": "10.200.0.149", "network": "wifi", "lineout": 2, "control": 1}, {"name": "Vaskerum", "pid": 718935263, "gid": -1994514722, "model": "HEOS 1", "version": "1.382.80", "ip": "10.200.0.151", "network": "wifi", "lineout": 0}, {"name": "Alrum", "pid": -1994514722, "gid": -1994514722, "model": "HEOS HomeCinema", "version": "1.382.80", "ip": "10.200.0.152", "network": "wifi", "lineout": 0}, {"name": "Stort Badeværelse", "pid": 1026187013, "model": "HEOS 1", "version": "1.382.80", "ip": "10.200.0.150", "network": "wifi", "lineout": 0}]}
