Strange Energy Measurement of Aeotec Smart Switch 6
irimi
Domoticz version: V4.10717
Post by irimi »
I have an Aeotec Smart Switch 6, recently a refrigerator is plugged for power and energy measurement.
Power measurement looks plausible but energy looks very strange:
Most time energy is 0 Wh but suddenly there is a peak of 1000kWh resp 1MWh :o , then zero again.
Any idea ?
EdddieN
Domoticz version: 4.9700
Re: Strange Energy Measurement of Aeotec Smart Switch 6
Post by EdddieN »
I have the same issue using a Aeotec ZW075 Smart Switch Gen5 (Wall plug switch). Power looks fine but energy peak is definitely not real.
Any idea where this is coming from? or even better how to delete it?
Using Synology with Domoticz Version: 3.5877
Screen Shot 2016-11-30 at 16.23.58.png (179.54 KiB) Viewed 1144 times
11101101 - www.machinon.com
Varazir
Post by Varazir »
Strange I can't get any value from my ZW075 Smart Switch Gen5 switch.
Edit : My problem was fixed with the latest beta
Last edited by Varazir on Wednesday 07 December 2016 20:59, edited 1 time in total.
Raspberry PI 4 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Several IKEA devices/z-wave devices
EdddieN
Post by EdddieN »
How long did you have it running? It usually takes a bit of time to start sending power or energy data.
Are you able to control it?
EdddieN
Post by EdddieN »
This has happened again but with a different socket (TKB), is this an issue with the hardware getting a jump for no reason? I wish I could see the logs of this entry received by Domoticz but probably realised too late...
Is there a way to find out if this is a Domoticz or hardware issue?
Screen Shot 2017-02-07 at 19.15.52.png (131.27 KiB) Viewed 1042 times
EdddieN
Post by EdddieN »
Screen Shot 2017-02-20 at 21.03.01.png (250.91 KiB) Viewed 1023 times
Does any one know how to remove the peaks? This has happened again with a different socket
