jorcat
Does anybody tried this suite with Domoticz?
This smart suite is very cheap, but I don't know if their modules/protocols are compatible with Domoticz. It seems that use ZigBee protocol, but I can't find more info, or a API to interact with the items.
http://xiaomi-mi.com/news-and-actions/r ... mart-home/
http://xiaomi-mi.com/mi-smart-home/xiao ... -home-kit/
More info:
there are four main sensor devices:
-Main hub that provides interaction between sensors and processing of incoming signals and then loads data to network;
-Motion Sensor;
-Sensors for installation on a door or window, signaling their opening;
-Technological analogue of doorbell in a wireless version.
More info:
-Motion Sensor;
jjnj
Those are lovely priced products!
Verstuurd vanaf mijn LG-H850 met Tapatalk
jammiejammie
well this looks awesome..... i'm keeping my eye on this topic....
jammiejammie
I see there is some chatter over this product at smartthings:
https://community.smartthings.com/t/9-z ... s/28607/73
DasK
Any news? Is it possible to control Xiaomi devices with Domoticz? It would be great
deennoo
Xiaomi didn't already release any API for those devices.
Not they will, but maybe an IFTTT rules or this new Google Home compatibilty
http://domo-attitude.fr
deennoo
Got a great news !
Finally some one start to hack Xiaomi SmartHome hardware :
https://notes.jmsinfor.com/blog/post/admin/Xiaomi-Hub
- corbin
Looks promising, have you got the Xiaomi Hub?deennoo wrote:Got a great news !
deennoo
Not yet asking for a cotation to various reseller on ali.
Programmer don't speak about xiaomi temp sensor
Do you plan to made a domoticz hardware support ?
- corbin
It would be awesome to get working with Domoticz, and I would try, but so far could not enable developer mode on my Hub. Might not be the right version.
I've still got some fixes to do for the Yeelight anyway.
deennoo
Gateway looks need 1.41 fw.corbin wrote:It would be awesome to get working with Domoticz, and I would try, but so far could not enable developer mode on my Hub. Might not be the right version.
I order a full kit pir, door, switch, temp, cube gateway hopping they will arrive soon.
2 domoticz integration way is possible :
- Native as a new hardware
- And MQTT one, using node red and a parser
- corbin
got developer mode enabled, and can see messages with Wireshark. Deennoo, when do you expect your kit arrives? Mine took 2-3 months after it got sent to the wrong country.
deennoo
Just order it, actually it take more than 30 days from china to france with free ali shipping.
We have to finish yeelight first.
Have you test py script + mqtt mentioned before ?
- corbin
I'm starting a plugin for the gateway, can use some of what I learnt with Yeelights to help. Haven't tried to get the py script going. Do have simple C# code that listens to the UDP packets.
deennoo
If it works that great !
Get a how to about how to transform a xiaomi switch into a real switch.
- corbin
The first thing I plan to get working is the motion sensors, I know this will be straight forward. It would be good if you can help test when your order arrives, even better if you can help writing the code!
piotr
Integration in Home-Assistant almost done: https://community.home-assistant.io/t/x ... ome/863/65
- corbin
Xiaomi Gateway with motion sensors working in Domoticz
- devices1.PNG (22.81 KiB) Viewed 55063 times
- hardware1.PNG (73.39 KiB) Viewed 55063 times
deennoo
Great !!! What about communication speed ?
Does your motion sensor is update as faster than the gateway ?
