Ok it's working nowHi al,
Trying to install the program and running npm start i get the following code. What am i doing wrong?
I installed it on my raspberry pi with raspbian jessie
node version 7.2.0
npm version 3.10.9
pi@raspberrypi:~/node-sonos-http-api $ npm start > [email protected] start /home/pi/node-sonos-http-api > node server.js module.js:472 throw err; ^ Error: Cannot find module 'request' at Function.Module._resolveFilename (module.js:470:15) at Function.Module._load (module.js:418:25) at Module.require (module.js:498:17) at require (internal/module.js:20:19) at /home/pi/node-sonos-http-api/node_modules/request-promise/lib/rp.js:26:24 at Object.<anonymous> (/home/pi/node-sonos-http-api/node_modules/request-promise/lib/rp.js:33:3) at Module._compile (module.js:571:32) at Object.Module._extensions..js (module.js:580:10) at Module.load (module.js:488:32) at tryModuleLoad (module.js:447:12) at Function.Module._load (module.js:439:3) at Module.require (module.js:498:17) at require (internal/module.js:20:19) at Object.<anonymous> (/home/pi/node-sonos-http-api/node_modules/sonos-discovery/lib/services/deezer.js:2:17) at Module._compile (module.js:571:32) at Object.Module._extensions..js (module.js:580:10) npm ERR! Linux 4.4.32-v7+ npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "start" npm ERR! node v7.2.0 npm ERR! npm v3.10.9 npm ERR! code ELIFECYCLE npm ERR! [email protected] start: `node server.js` npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the [email protected] start script 'node server.js'. npm ERR! Make sure you have the latest version of node.js and npm installed. npm ERR! If you do, this is most likely a problem with the sonos-http-api package, npm ERR! not with npm itself. npm ERR! Tell the author that this fails on your system: npm ERR! node server.js npm ERR! You can get information on how to open an issue for this project with: npm ERR! npm bugs sonos-http-api npm ERR! Or if that isn't available, you can get their info via: npm ERR! npm owner ls sonos-http-api npm ERR! There is likely additional logging output above. npm ERR! Please include the following file with any support request: npm ERR! /home/pi/node-sonos-http-api/npm-debug.log
Step by step guide: Sonos integration
DomoRies
Re: Step by step guide: Sonos integration
Last edited by DomoRies on Tuesday 13 December 2016 12:54, edited 2 times in total.
Hi, I'm running domoticz on Synology...somehow it looks like the program hangs after npm starts.... any suggestions?
~# cd node-sonos-http-api
root@iSIM_NAS:~/node-sonos-http-api# npm start
> [email protected] start /root/node-sonos-http-api
> node server.js
2016-11-26T19:30:28.418Z INFO no settings file found, will only use default settings
2016-11-26T19:30:34.097Z INFO Presets loaded: { example:
{ players:
[ { roomName: 'WOONKAMER', volume: 10 },
{ roomName: 'STUDEERKAMER', volume: 10 },
{ roomName: 'Office', volume: 10 },
{ roomName: 'Bedroom', volume: 10 },
{ roomName: 'TV Room', volume: 15 } ],
playMode: { shuffle: true, repeat: 'all', crossfade: false },
pauseOthers: false,
favorite: 'My example favorite' } }
2016-11-26T19:30:34.262Z INFO http server listening on port 5005
> node server.js
{ players:
pauseOthers: false,
mabo21
Hi Holland,
thanks for the great solution! But i have a few issues and hope you can help me in any way... I have done everything you described, but when i start npm i get some errors.
Server.js is still running.
Node.js version is 4.4.2
npm version is 4.0.5
Please can you take a look and help me?
Thanks a lot and best,
Mario
ash-4.3# npm start
> [email protected] start /volume1/homes/admin/node-sonos-http-api
> node server.js
2017-01-08T14:55:13.489Z INFO no settings file found, will only use default settings
2017-01-08T14:55:14.669Z INFO Presets loaded: { example:
{ players:
[ { roomName: 'Bathroom', volume: 10 },
{ roomName: 'Kitchen', volume: 10 },
pauseOthers: false,
2017-01-08T14:55:15.281Z ERROR Port 5005 seems to be in use already. Make sure the sonos
-http-api isn't
already running, or that no other server uses that port. You can specify an alternat
ive http port
with property "port" in settings.json
npm ERR! Linux 3.10.77
npm ERR! argv "/volume1/@appstore/Node.js_v4/usr/local/bin/node" "/usr/local/bin/npm" "s
tart"
npm ERR! node v4.4.2
npm ERR! npm v4.0.5
npm ERR!
npm ERR! /volume1/homes/admin/node-sonos-http-api/npm-debug.log
ash-4.3#
Mario
mabo21
I have uninstall everything and started again. Now it runs without issues.
Best,
Mario
Best,
Mario
mabo21 wrote:Hi Holland,
Server.js is still running.Code: Select all
ash-4.3# npm start > [email protected] start /volume1/homes/admin/node-sonos-http-api > node server.js 2017-01-08T14:55:13.489Z INFO no settings file found, will only use default settings 2017-01-08T14:55:14.669Z INFO Presets loaded: { example: { players: [ { roomName: 'Bathroom', volume: 10 }, { roomName: 'Kitchen', volume: 10 }, { roomName: 'Office', volume: 10 }, { roomName: 'Bedroom', volume: 10 }, { roomName: 'TV Room', volume: 15 } ], playMode: { shuffle: true, repeat: 'all', crossfade: false }, pauseOthers: false, favorite: 'My example favorite' } } 2017-01-08T14:55:15.281Z ERROR Port 5005 seems to be in use already. Make sure the sonos -http-api isn't already running, or that no other server uses that port. You can specify an alternat ive http port with property "port" in settings.json npm ERR! Linux 3.10.77 npm ERR! argv "/volume1/@appstore/Node.js_v4/usr/local/bin/node" "/usr/local/bin/npm" "s tart" npm ERR! node v4.4.2 npm ERR! npm v4.0.5 npm ERR! code ELIFECYCLE npm ERR! [email protected] start: `node server.js` npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the [email protected] start script 'node server.js'. npm ERR! Make sure you have the latest version of node.js and npm installed. npm ERR! If you do, this is most likely a problem with the sonos-http-api package, npm ERR! not with npm itself. npm ERR! Tell the author that this fails on your system: npm ERR! node server.js npm ERR! You can get information on how to open an issue for this project with: npm ERR! npm bugs sonos-http-api npm ERR! Or if that isn't available, you can get their info via: npm ERR! npm owner ls sonos-http-api npm ERR! There is likely additional logging output above. npm ERR! Please include the following file with any support request: npm ERR! /volume1/homes/admin/node-sonos-http-api/npm-debug.log ash-4.3#
Mario
Trigun
- Domoticz version: 4.10717
sorry but I am a complete noob out here.
I really like to use this feature for my domoticz setup but I am not getting any further.
so this is what I did.
>checked that I did have node version 4.0.0
>did the clone
>sudo npm install --production
>> it installed without any error, assuming that I did the right thing.
but when I enter PM2 start server.js I get the following: command not found.
when I enter: npm start it works perfectly and I even get a page when entering domoticzip:5005
creating a switch is done correctly
But this is where I get stuck.
I have the feeling that I need to setup a config file where I confige the rooms and sonos Ip etc.
but have no idea how to get any further.
I hope someone cn help me out here.
Thanks in advance!
>did the clone
Thanks in advance!
Holland
- Domoticz version: Beta Ch
@Trigun
You need to jump into the sonos-http-api directory; then you can issue: pm2 start server.js
Trigun
Hi Holland, thank you for your reply. but so far no luck. I did what you told but it doesn't seem to start.
below a screenshot of what I did.
Can you please help me out here?
Thanks in advance!
Thanks in advance!
- G3rard
- Target OS: -
- Domoticz version: No
If you are on on of the latest beta's then there also is a Python plugin available for Sonos.
Check http://www.domoticz.com/forum/viewtopic ... 3&p=116118 for more information.
Not using Domoticz anymore
Holland
@Trigun;
Have you installed PM2? It's not part of the Domoticz sd image, or Jessie Light
See http://pm2.keymetrics.io/docs/usage/quick-start/
Trigun
Hi Holland, I got it working!Holland wrote:@Trigun;
NPM start did the job! (since I don't have PM2 running
next thing is to keep it running when I close the session.
sorry I am a huge noob with commandline. do you perhaps have any suggestions?
Thanks again !
mvzut
Hi guys,
Are you aware that there is a new way to integrate hardware in Domoticz, via Python plugins, and that there is already an excellent Sonos plugin created in this way? See viewtopic.php?t=15543
I had it running within a few minutes, without installing anything. There is one prerequisite though, and that is that you use the latest beta.
Trigun
Hi mvzut, thanks for you reply,mvzut wrote:Hi guys,
I have to say that the solution with NPM also works fantastic!
If I manage to get it working after closing the putty session, it works like a charm!
I am aware that it is basic Linuc knowledge for this solution but hey, I'm just starting/beginning
if there is anyone who would like to help a noob out here, thanks in advance!
Trigun
@ Holland,
thanks for the solution! I installed PM2 and its working perfectly!
what specifi things do I need to edit in de Lua script to get the player state?
Thanks again!
Thanks again!
Holland
@Trigun,
I use the following lua to check a couple of things related to the Sonos group in the livingroom(woonkamer), e.g the status, but also set Sonos to pauze when tv is switched on etc.
json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()
local sonos=assert(io.popen('curl http://ip:5005/eetkamer/state'))
local status = sonos:read('*all')
sonos:close()
local jsonStatus = json:decode(status)
local tv_woonkamer_status = 'TV Woonkamer System Alive'
local sonos_woonkamer = 'Sonos Woonkamer/Eetkamer'
--print("Eerste JSON stappen met LUA")
--print(status)
-- print(jsonStatus)
--playerstate = jsonStatus['playerState']
playbackState = jsonStatus['playbackState']
artist = jsonStatus['currentTrack']['artist']
title = jsonStatus['currentTrack']['title']
album = jsonStatus['currentTrack']['album']
type = jsonStatus['currentTrack']['type']
--streaminfo = jsonStatus['currentTrack']['streamInfo']
if (playbackState == "STOPPED" or playbackState == "PAUSED_PLAYBACK" or playbackState == "PLAYING") then
if (playbackState == "PLAYING") then
if type == "radio" then
print('Woonkamer/Eetkamer Sonos status: ' ..playbackState.. ' ' ..type.. ' Titel: '..title)
if artist ~= nil then
print('Badkamer Sonos status: ' ..playbackState.. ' Artiest: ' ..artist.. ' Titel: '..title)
print('Badkamer Sonos status: ' ..playbackState.. ' Titel: '..title)
if (uservariables["SonosWoonkamerStatus"] == "PAUSED") then
commandArray['Variable:SonosWoonkamerStatus']='PLAYING'
print("Uservar SonosWoonkamer updated to PLAYING")
if (playbackState == "STOPPED" or playbackState == "PAUSED_PLAYBACK") then
print('Woonkamer/Eetkamer Sonos Status: ' ..playbackState)
if (uservariables["SonosWoonkamerStatus"] == "PLAYING") then
commandArray['Variable:SonosWoonkamerStatus']='PAUSED'
print("Uservar SonosWoonkamer updated to PAUSED")
--print("2")
print('<font color="red">Woonkamer/Eetkamer: SONOS-HTTP-API is off-line</font>')
switch_status_sonos_woonkamer_eetkamer = otherdevices["Sonos Woonkamer/Eetkamer"]
print('Sonos Woonkamer/Eetkamer Switch Status: ' ..switch_status_sonos_woonkamer_eetkamer)
if otherdevices["Sonos Woonkamer/Eetkamer"] == 'Pauze' then
print('Sonos Woonkamer/Eetkamer Switch Status is correct, should be PAUZE: ' ..switch_status_sonos_woonkamer_eetkamer)
print('Sonos Woonkamer/Eetkamer Switch Status not correct, should be PAUZE: ' ..switch_status_sonos_woonkamer_eetkamer)
commandArray['UpdateDevice'] = '43|20|20'
if otherdevices["Sonos Woonkamer/Eetkamer"] == 'Play' then
print('Sonos Woonkamer/Eetkamer Switch Status is correct, should be PLAY: ' ..switch_status_sonos_woonkamer_eetkamer)
print('Sonos Woonkamer/Eetkamer Switch Status not correct, should be PLAY: ' ..switch_status_sonos_woonkamer_eetkamer)
commandArray['UpdateDevice'] = '43|10|10'
if devicechanged[tv_woonkamer_status] == 'On' then
print("TV Woonkamer is net aangezet, status Sonos Woonkamer onderzoeken")
if (playerstate == "PLAYING" or playbackState == "PLAYING") then
print("Sonos woonkamer heeft status PLAYING, Sonos Woonkamer/Eetkamer wordt uitgeschakeld")
commandArray[sonos_woonkamer]='Set Level 20'
return commandArray-
markiemajax
- Domoticz version: 3.4834
I got it partly working, but what ip do i use?
i got 3 sonos speakers (1 playbar, 2 sonos 1)
Or is it the ip of my domoticz (raspberry)?
Holland
Just use the ip address of your sonos player. If you have grouped sonos players, use the ip address of the zone coordinator.
markiemajax
This is the log i get. It is still not working.
I put my script in attechment.
- script_device_sonos_tv_woonkamer.zip
- (1.12 KiB) Downloaded 137 times
markiemajax
Yes i get status "error". I use the ip of my domoticz. If i use the ip of my sonos playbar the site is not available.
Something is wrong, but i don't know what.
markiemajax
