Script to disable/enable events
Slinkos
Domoticz version: 3.4834
Post by Slinkos »
I'm thinking to make a virtual switch named "Vacation" for whenever I will be gone from home for a while. My purpose of this switch that when it's on, it will disable the blocky events that I specify in the script), and enable all those events again when I turn the vacation swithc off.
Offcourse I could also rebuild al this events with the statement that "Vacation" has to be off, but I think this is a more clean solution.
Slinkos
Re: Script to disable/enable events
Post by Slinkos »
Is there no script to do this?
Domosapiens
Domoticz version: V3.5981
Post by Domosapiens »
Did you look for the possibilities of "Timer Plan" under Setup - Other?
Slinkos
Post by Slinkos »
No... I also can't find the menu you are suggesting.
Domosapiens
Update your version?
toreandre
Post by toreandre »
One way would be to make your events check for the vacation switch status.
If the vacation switch is OFF then execute events, if its ON do nothing.
lukcinek
Post by lukcinek »
Slinkos wrote:Hi all,
You should add uservariable in Settings-->More Options-->User variables
Put some name of Your Variable --> MyScriptRun
Type of Variable --> Integer
Variable --> 1
You must add some LUA code to Your Events.
I paste my code that turns off my lights automatically when some time elapses and no motion is discovered.
script_time_nomotion.lua
local motion_switch = 'PiR - Kitchen'
local nomotion_uservar = 'nomotionCounter'
local status_switch = 'Lamp - ON'
local noRun = uservariables["MyScriptRun"]
local no_motion_minutes = tonumber(uservariables[nomotion_uservar])
          if (otherdevices[motion_switch] == 'Off') then
               no_motion_minutes = no_motion_minutes + 1
               --print('<font color="red">No motion has been detected for: ' ..no_motion_minutes.. ' minutes</font>')
               no_motion_minutes = 0
          if tonumber(noRun) == 1 then
               if otherdevices[status_switch] == 'On' and no_motion_minutes > 10 then --change the 30 to the amount of minutes you prefer
                    nomotion_uservar= "0"
                    commandArray[status_switch]='Off'
commandArray['Variable:' .. nomotion_uservar] = tostring(no_motion_minutes)
You must modify this script...sorry I don't know nothing about programming:(
You should make virtual switch (Vacation) and in field:
--> Enable action put something like this:
 http://192.168.0.15:8080/json.htm?type=command&param=updateuservariable&vname=MyScriptRun&vtype=integer&vvalue=1
--> Disable action put something like this:
 http://192.168.0.15:8080/json.htm?type=command&param=updateuservariable&vname=MyScriptRun&vtype=integer&vvalue=0
Change 192.168.0.15:8080 to Your ip and port.
In my case when I turn On my Virtual switch --> My Lua script works and my lights in kitchen Turns off when some time elapses and no motion is discovered.
When i turn Off my Virtual switch --> My lua script doesn't work and my kitchen light are turned on all the time.
Sorry for my English.
Best regards
Slinkos
Post by Slinkos »
Domosapiens wrote:Update your version?
I am on the latest stable
