I'm thinking to make a virtual switch named "Vacation" for whenever I will be gone from home for a while. My purpose of this switch that when it's on, it will disable the blocky events that I specify in the script), and enable all those events again when I turn the vacation swithc off.
Offcourse I could also rebuild al this events with the statement that "Vacation" has to be off, but I think this is a more clean solution.
Script to disable/enable events
Slinkos
- Domoticz version: 3.4834
Re: Script to disable/enable events
Is there no script to do this?
- Domosapiens
- Domoticz version: V3.5981
Did you look for the possibilities of "Timer Plan" under Setup - Other?
Slinkos
No... I also can't find the menu you are suggesting.
- Domosapiens
Update your version?
One way would be to make your events check for the vacation switch status.
If the vacation switch is OFF then execute events, if its ON do nothing.
lukcinek
HiSlinkos wrote:Hi all,
You should add uservariable in Settings-->More Options-->User variables
Put some name of Your Variable --> MyScriptRun
Type of Variable --> Integer
Variable --> 1
You must add some LUA code to Your Events.
I paste my code that turns off my lights automatically when some time elapses and no motion is discovered.
script_time_nomotion.lua
local motion_switch = 'PiR - Kitchen'
local nomotion_uservar = 'nomotionCounter'
local status_switch = 'Lamp - ON'
local noRun = uservariables["MyScriptRun"]
local no_motion_minutes = tonumber(uservariables[nomotion_uservar])
if (otherdevices[motion_switch] == 'Off') then
no_motion_minutes = no_motion_minutes + 1
--print('<font color="red">No motion has been detected for: ' ..no_motion_minutes.. ' minutes</font>')
no_motion_minutes = 0
if tonumber(noRun) == 1 then
if otherdevices[status_switch] == 'On' and no_motion_minutes > 10 then --change the 30 to the amount of minutes you prefer
nomotion_uservar= "0"
commandArray[status_switch]='Off'
commandArray['Variable:' .. nomotion_uservar] = tostring(no_motion_minutes)
You should make virtual switch (Vacation) and in field:
--> Enable action put something like this:
http://192.168.0.15:8080/json.htm?type=command¶m=updateuservariable&vname=MyScriptRun&vtype=integer&vvalue=1Code: Select all
http://192.168.0.15:8080/json.htm?type=command¶m=updateuservariable&vname=MyScriptRun&vtype=integer&vvalue=0 In my case when I turn On my Virtual switch --> My Lua script works and my lights in kitchen Turns off when some time elapses and no motion is discovered.
When i turn Off my Virtual switch --> My lua script doesn't work and my kitchen light are turned on all the time.
Sorry for my English.
Best regards
Slinkos
I am on the latest stableDomosapiens wrote:Update your version?
