Custom Graph for Utility
jurgen
Domoticz version: stable
Post by jurgen »
Hi All,
In the menus of domoticz we have Temperture which has a functionality called " Custom Graph" but in the Utility we don't have that option.
I would like tot combine two or more different sensors in one graph and save that custom graph on the dashboard.
I have a sensor for a Smartmeter and a sensor for my solar panels which gives me two different graphs.
Is this functionality on the roadmap or is it possible to create one with a custom script?
Thank you!
macieiks
Re: Custom Graph for Utility
Post by macieiks »
That would be also perfect feature for me - comparing two energy meters with gas meter. Looking forward for it.
Cheers
RPI2 + RFLink + PiFace D2 + Aeon Z-Wave Gen5 + Foscams FI9821P&R2 + MySensors + UPS APC Back-UPS 950VA
RPI2 + RFXtrx433e + Foscams FI9821P + MySensors + UPS APC Back-UPS 950VA
RPIB+ + TP-Link MR3420 + Huawei E173 GarageDomoticz :)
jurgen
Post by jurgen »
Hi All,
Does anyone know how to combine utility graph's?
Silenus
Domoticz version: 4.9701
Post by Silenus »
This still doesn't seem available in v3.5877.
I even think it's useful to combine graphs of everything you have data for.
For example:
I want to make a combined graph of the Switch "Nest HeatingOn" and Temperature "Nest".
Combining those 2 will give me a graph where I can see the temperature change after the Nest turned on the heating.
Mike
Domoticz version: 3.5827
Post by Mike »
In an attempt to improve my heating control script I have a dummy Temperature sensor that gets updated with the Thermostat Setpoint (utility) to be able to plot a chart like this
temp util.png (128.25 KiB) Viewed 6785 times
would be nice to see gas consumption or boiler on-time in the same chart but they would need a second Y-axis
if domoticz could produce more options to plot combined data for analysis that would be great!
Somewhat in line with this,... When I click on a custom sensor icon on the floorplan I get a blank page, and not the log as for any other temp/weather/utility sensor.
In your case Silenus, you could update the dummy sensor with a value of say 17 when off, and 22 when on.
Silenus
Post by Silenus »
Mike wrote:In your case Silenus, you could update the dummy sensor with a value of say 17 when off, and 22 when on.
Good point, I created a small LUA script which updates the value of the dummy sensor to the Nest Setpoint value.
Still, it would be useful to combine any other data in the same graph.
I've seen graphs in Domoticz where they use multiple Y-axis on the left side, but I can't recall where though.
If I found it again I'll post it.
Edit: It actually was on the Custom Graphs page for Temperatures
Patricen
Domoticz version: Beta rel
Post by Patricen »
On the custom graph page, there is a setpoint value check box, but I have no idea how it is operating. Any idea?
