You need to set off delay. I've set it to 10 seconds but you can use what ever suits you.SteGe wrote:I also ordered the Oudi door sensor. But when I add it as a switch it only turn on, and never gets off (also won't turn off when I click it by hand). Should I change it to another type of switch?
Low cost window/door sensor
jarwis
- Domoticz version: 2.3530
Re: Low cost window/door sensor
- Screen Shot 2016-09-08 at 6.30.45 PM.png (168.12 KiB) Viewed 6126 times
SteGe
Thx, that's works! Now I'm getting a notification when somebody opens my postbox. Will get a camera in the near future so that I can get a picture when somebody is at the door or opens the letterbox.
Synology DS3615xs | Raspberry pi 3b |
RFXtrx433E | MySensors | Z-wave | Philips Hue | Ikea Tradfri |
Sunscreen | Power switches | Toon | Harmony | UE Smartradio |
Weatherstation | Doorbell | Letterbox reader | Lux | Temp | Humidity | Motion |
sploutchi
Hi all !
I just found this product : https://fr.aliexpress.com/af/detecteur- ... lanktest=0
Do you know if it is compatible with Domoticz , if yes, which protocol.
Do you know if it send ON and OFF signal to notify when a door is open and when it is closed?
Thx !
Bastien
Thx !
Bastien
jackderuiter
just bought this sensor and can report it's working ok with RFLink and Domoticz. Battery (23A) was included altough not clearly specified. Just ordered another two of these. mounted it in my snail mail box by soldering a wired reed contact so it fitted better and the main unit could be mounted on the inside of the door. Don;t know yet about battery life, but we'll see. Noticed some other sensors in Domotics device list that are probably the same (ev1527 and eurodomest) with some similar codes...
- Treve
- Domoticz version: v4.11474
Witch signal generates this sensor? on/off, on or off?jackderuiter wrote:just bought this sensor and can report it's working ok with RFLink and Domoticz. Battery (23A) was included altough not clearly specified. Just ordered another two of these. mounted it in my snail mail box by soldering a wired reed contact so it fitted better and the main unit could be mounted on the inside of the door. Don;t know yet about battery life, but we'll see. Noticed some other sensors in Domotics device list that are probably the same (ev1527 and eurodomest) with some similar codes...
- RFXtrx433E,
- AEON Labs ZW090 Z-Stick Gen5 EU
- Hue v2.1
- Raspberry Pi 3 Model B, Raspbian Stretch Full on USB-Stick.
- Domoticz 4.11474
Devices: KaKu, Z-Wave, Hue.
for testing:
Raspberry 4, 2GB, SSD
Domoticz 2022.1
Ikea Hub, Fyrtur curtain
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
jackderuiter
only on. However somtimes ip pops up as a ev1527 and then as eurodomest, both with other id's so don't know if it's a domoticz/rflink/transmitter issue.. Worked ok last week, but since this weekend it switched ID..
jackderuiter
Just received another 433 door contact with ev1527. really Nice casing compared to some other uggly Chinese door sensors. Don't know yet about battery Life ofcourse but we will see. Only reporting on signal as usual with these sensors.
I bought several Kerui D026, they are cheap and are looking very nice! Works fine with domoticz + RFX
jumping
- Domoticz version: 3.9227
Does the kerui d026 generate on/off signal?josimd wrote:I bought several Kerui D026, they are cheap and are looking very nice! Works fine with domoticz + RFX
I'm looking for a cheap door sensor able to send an on/off signal
thanks
Domoticz + Mysensors 2.0 ESP8266 GW + RFlink + Philips Hue 2.0 + Netatmo Thermostat
Yes, generates an On and Off pulse..
robertje221
How did you get it worked with a RFX?josimd wrote:I bought several Kerui D026, they are cheap and are looking very nice! Works fine with domoticz + RFX
How did you get it worked with a RFX?robertje221 wrote:josimd wrote:I bought several Kerui D026, they are cheap and are looking very nice! Works fine with domoticz + RFX
Yes, works with RFX
robertje221
How did you add the kerui d026 sensor? Is it protocol lightning 4 and then learning mode or manual mode?josimd wrote:How did you get it worked with a RFX?robertje221 wrote:josimd wrote:I bought several Kerui D026, they are cheap and are looking very nice! Works fine with domoticz + RFX
Yes, works with RFX
Yes lightning 4 (hardware tab) after sensing the kerui it will apear in 'apparaten'robertje221 wrote:How did you add the kerui d026 sensor? Is it protocol lightning 4 and then learning mode or manual mode?josimd wrote:How did you get it worked with a RFX?robertje221 wrote:
Yes, works with RFX
ArieKanarie
I bought some Kerui-like sensors form AlieExpress, and connected them yesterday without any problems. (PT2262, lightning 4)
That is.... 3 of 5 connected flawless when I used the learning mode.
But 2 of the sensors won't connect, no matter what I try, the sensor has a red led which flashes when activated (sensor disconnects), and that still works, I only get so see the hiddious "Time Out, Try again" in Domoticz.
Any suggestions what I could try?
b_weijenberg
- Target OS: -
@ArieKanarie: please check with RFXmngr with only Lighting4 and undec on enabled. If you don't receive all contact support rfxcom.com
On request a beta version Ext2 firmware is available for real Kerui sensors to receive these sensors as security sensor.
RFX-433, RFX-433EMC, RFX-868
ArieKanarie
@b_weijenberg
When connected with RFXmngr I can see the messages being transmitted.
Connected the rfxtrx back to the pi, (updated the firmware to 1011) and learning the switch still fails.
Packettype = UNDECODED RF Message
UNDECODED ARC:0CFCE0
UNDECODED ARC:12DFF380
UNDECODED ARC:0EFF38
UNDECODED ARC:0BF980
UNDECODED ARC:0AFC40
UNDECODED ARC:11BFE700
UNDECODED ARC:14F7FCE0
UNDECODED ARC:0FFF9C
b_weijenberg
- Target OS: -
The sensor does not transmit correct Lighting4 packets and is not a Kerui compatible sensor.
Contact support rfxcom.com for further investigation.
Does this one work with ver1011? Or should I buy real Kerui-sensors? This one should have ON and OFF mode too
https://www.aliexpress.com/item/High-gr ... 2167&tpp=1
RFXcom433e ver1009,Raspberry Pi,Domoticz v3.5877
KaKu:16c remote,dimmer,wall-sockets,sunscreenswitch
Promax:wall sockets Elro:wall sockets Somfy:RFY screens
TFA:weather station Chinese temperature sensors, smoke detectors, power switches
sploutchi
Hi !
I just received these 6 KERUI door sensor and i try to configure it in domotic.
When i open the door, the device "Ouverture chambre" receive a message
When i close the door, the device "
In "Switch" tab ... no update on devices ....
Please can someone post screenshot of his device configuration pls ?
