Notifications always appear on two lines
leecollings
Post by leecollings »
I've tried to use notifications on my phone with both Prowl and Pushover. I think I'm going to stick with Pushover, for the Android support.
But anyway, I've entered a message in the 'Custom message' field as such:
There is someone at the front door.
But when the notification comes on my phone, it appears twice (see screenshot).
Is there anyway I can set a title, and the main notification text in the above Custom Message field? Or at least, just have one line showing?
ThinkPad
Re: Notifications always appear on two lines
Post by ThinkPad »
I think it is the same as this problem: http://domoticz.com/forum/viewtopic.php?f=6&t=6352 (body is used as subject also). But according to gizmocuz it should be fixed >= version 2411
leecollings
Well in my version of Domoticz, which is higher (which is what I think that's referring to) it's still appearing in both the subject and body.
Maybe there should be two fields (like sending a custom notification from Settings), rather than just one field for 'Custom Message' for a switch?
leecollings
Does this happen for anyone else or is it just me? I would think it a bit strange if it was, I'm not doing anything special...
It happens on both Pushover and Prowl though, and even carries the same behaviour through to my mac. So I believe there should be something within Domoticz to allow separation of Subject and Body on custom messages.
Has anyone got any ideas?
leecollings
Anyone getting the same behaviour?
gizmocuz
Post by gizmocuz »
leecollings wrote:Anyone getting the same behaviour?
it is called "subject" and "Body", both are the same in this case
leecollings
Yeah, im understanding that. Is there anyway to provide both a subject and body message within the one custom message field in Domoticz?
malarcy
Post by malarcy »
Did you ever get anywhere on this - I get the same effect - from a notification on a manually created dummy switch custom message appears as both Subject and Body - if no custom message then I get <device name> >> <state> (e.g. test 1 >> OFF ) as both subject and body.
leecollings
No, didn't get anywhere. No one replied with any additional info, and I didn't end up working it out.
I might go back to it, as there's been quite a few updates since, and see if it's any different.
jvdz
Domoticz version: 4.107
Post by jvdz »
Looking at the source it looks like the subject should be set to "Domoticz" in case the subject is equal to the message, so guess they are not 100% the same or something isn't working as it is supposed to.
Jos
JeroenL
Domoticz version: 2023.2
Post by JeroenL »
Hi, do not know what I changed, but since today, I get all my notifications 7 times. Independant of the system (email / Prowl / Pushbullet).
Anyone a clue where to look?
Thanks.
UPDATE:
Got it fixed: My devices were recursively triggering each-other, hence multiple notifications were send. I moved the devices to slave, and made the master send the notifications, this fixes it.
