Notifications always appear on two lines
- leecollings
I've tried to use notifications on my phone with both Prowl and Pushover. I think I'm going to stick with Pushover, for the Android support.
But anyway, I've entered a message in the 'Custom message' field as such:
There is someone at the front door.
But when the notification comes on my phone, it appears twice (see screenshot).
Is there anyway I can set a title, and the main notification text in the above Custom Message field? Or at least, just have one line showing?
- Pushover-Notification-iOS.PNG (277.13 KiB) Viewed 2220 times
ThinkPad
Re: Notifications always appear on two lines
I think it is the same as this problem: http://domoticz.com/forum/viewtopic.php?f=6&t=6352 (body is used as subject also). But according to gizmocuz it should be fixed >= version 2411
- leecollings
Well in my version of Domoticz, which is higher (which is what I think that's referring to) it's still appearing in both the subject and body.
Maybe there should be two fields (like sending a custom notification from Settings), rather than just one field for 'Custom Message' for a switch?
- leecollings
Does this happen for anyone else or is it just me? I would think it a bit strange if it was, I'm not doing anything special...
It happens on both Pushover and Prowl though, and even carries the same behaviour through to my mac. So I believe there should be something within Domoticz to allow separation of Subject and Body on custom messages.
Has anyone got any ideas?
- leecollings
Anyone getting the same behaviour?
- gizmocuz
it is called "subject" and "Body", both are the same in this caseleecollings wrote:Anyone getting the same behaviour?
- leecollings
Yeah, im understanding that. Is there anyway to provide both a subject and body message within the one custom message field in Domoticz?
Did you ever get anywhere on this - I get the same effect - from a notification on a manually created dummy switch custom message appears as both Subject and Body - if no custom message then I get <device name> >> <state> (e.g. test 1 >> OFF ) as both subject and body.
- leecollings
No, didn't get anywhere. No one replied with any additional info, and I didn't end up working it out.
I might go back to it, as there's been quite a few updates since, and see if it's any different.
- jvdz
- Domoticz version: 4.107
Looking at the source it looks like the subject should be set to "Domoticz" in case the subject is equal to the message, so guess they are not 100% the same or something isn't working as it is supposed to.
Jos
Jos
JeroenL
- Domoticz version: 2023.2
Hi, do not know what I changed, but since today, I get all my notifications 7 times. Independant of the system (email / Prowl / Pushbullet).
Anyone a clue where to look?
Thanks.
UPDATE:
Got it fixed: My devices were recursively triggering each-other, hence multiple notifications were send. I moved the devices to slave, and made the master send the notifications, this fixes it.
Thanks.
UPDATE:
