Hallo to everyone. I have one question. If i take in cmd the command ping -t to the ip of Domoticz the respons is very variable. 3/4 packets in 2/3 ms, 1/2 in 30/40 ms, another 1/2 in 120/130 ms and so on.
The Domoticz server is a rpi2 with usb/wireless adapter.
The ping command is send from a desktop PC wired connect to the ruoter at 1 gb speed.
As usual in a internal lan i think the ping still more continous.
Someone can tell me something about? ??? Thanks a lot.
Inviato dal mio GT-I9301I utilizzando Tapatalk
Ping time server domoticz
guantolento
- Domoticz version: LastBeta
Master (pi3) - MB sensors + Dummy + Sysfs gpio + 1 NodOn MSP-3 + 1 Aeotec DSB28 Energy Meter + 3 Danfoss RS Room + 7 Danfoss Z Thermostat + 1 Swiid Inter + 9 FGS222
Slave01 (pi2) - MB sensors + Dummy + Weather Underground + 2 FGS223 + 1 FGWPE/F
jannl
- Domoticz version: 2025.5.x
Re: Ping time server domoticz
The ping is obviously over a wireless network with a lot of interference from your domestic appliances, hence the difference in ping latency. Ping over for instance a gprs network shows even much bigger differences in the latency. But actually that should not really be a problem. (May be a reboot of you ap helps)
Flopp
- Target OS: -
Test with wired RPi. See if that helps, maybe you wifi dongle is damaged.
Check that nothing is running with high CPU on RPi, type "ps aux"
guantolento
Ok just i have one minute i take the same test with wired lan and i post here the different results.
guantolento
Good evening to everyone. I take some test. Now i ping the primary dns google 8.8.8.8 both from the rpi2 in wireless and from pc in wired.
This is the results:
RPI2
150 packets transmitted, 150 received, 0% packet loss, time 149142ms
rtt min/avg/max/mdev = 40.371/43.426/93.684/5.173 ms
PC Desktop
154 packets trasmitted, 154 received, 0% packet loss
min/avg/max = 38/40/128 ms
in this situation i think the trasmission is the same from rpi2 on 100mbs than on pc desktop on 1 gbps.
If i try to ping an internal lan the situation change:
RPI2 ping the router in 1.8 /7.4 ms
PC Desktop ping the router in 1.0 ms costant
RPI2
PC Desktop
