App doesn't connect to server - newbie issue? Topic is solved
Grappa
Post by Grappa »
am new on Domoticz (looking for a better solution than my current HomeWizard) and want to test the Android App (lite).
I have created a simple server setup on my Windows10 PC (want to move to Rasberry PI later) and do see my sensors and switches ok. However when I try to connect from App I do get the message:
Timeout or no connection
com.android.volley. TimeoutError
Please correct the data on the previous page
server address: ip-address of PC; Port 6144; Username & PW as created under Setup - More Options - Edit Users
In the logfile I do see: 2016-10-30 17:39:13.955 Incoming Domoticz connection from: 192.168.178.113 (which is the Android phone running the app)
Tried other android devices: same message.
Probably something stupid that I just failed to see... Who can help?
THANKS
Thomasdc
Re: App doesn't connect to server - newbie issue?
Post by Thomasdc »
i have the same problem
with the app 'imperihome' its working fine
EDIT
its working when i use it from outside the lan network.. (so with a 4g connection on my phone and portforwarding)
Egregius
Domoticz version: v2024.7
Post by Egregius »
can only be some error in address/domain name/port forwarding.
Grappa
Post by Grappa »
I tried imperihome: same result
I tried via 4G (and portforwarding): same result
I tried different devices: 3 different Windows devices (W10/W7), Synology and Raspberry Pi: same result
I tried 3 different Androids with the APP and an Iphone: same result
Domoticz server DOES see the connection comming in (2016-11-07 21:28:52.001 Incoming Domoticz connection from: 192.168.178.136) but the app times out.
If I enter a different portnr in the app I immediately get an error message. So the app does somehow communicate with the server.
Any ideas?
Grappa
Post by Grappa »
Found it.... :roll:
had set port in the app to 6144 and it should be 8080 :o
EdddieN
Domoticz version: 4.9700
Post by EdddieN »
Just hijacking the post a bit. I'm setting Imperihome too and it works fine on LAN but when trying to access remotely (with port forwarding and basic login auth) it doesn't work.
I can see on the logs (accessing remotely) that Imperihome is trying to log in but gets refused:
2016-11-22 12:54:39.968 Error: [web:8084] Failed authentication attempt, ignoring client request (remote address: 127.0.0.1)
I'm accessing remotely from my mobile phone 3G
The paremeter I'm using for remote access is a DNS:3002 and then user and password. Am I missing anything else?
SPEC: Running Domoticz 3.5877 on Synology 116
11101101 - www.machinon.com
EdddieN
Post by EdddieN »
Figured out what the issue is. I had to white list an IP under settings: 127.0.0.1 for Imperihome to work with a port forwarding. :)
