Thanks, will try it quickly and give you a feedback !gizmocuz wrote:Yes,disable mydomoticz and see if it keeps working.
We did some updates
domoticz in synology as package! Available now.
jnoel68
jnoel68
OK, good, since last update and mydomoticz up and running, I have no more issues, thx
- gizmocuz
thanks for the feedback
sanderl
Hi, I had Domotics running for several months on my synology 1815+ (as a sort of test thing next to Vera). But since a few months/weeks I can't access it anymore. I have to restart the package and then some time I can access it but it freezes/crashes in a few minutes. I added the beta link to the package center and then it updated to (the beta).
But this gives no relief. What do I have to do, where do I have to start troubleshooting?
- Egregius
- Domoticz version: v2024.7
Start with the logfile...
Problem is that it is cleared when domoticz is started.
This is a script that I use to push the power of my solar panels to domoticz. If domoticz doesn't respond it retries 2 more times. If all 3 actions failes it copies the logfile to another location and then stop/kills/starts domoticz. Could be an example of a script for you.
#!/bin/bash
H=$(date +%H)
if (( 9 <= 10#$H && 10#$H < 23 )); then
string=$(tail -1 $(/bin/ls -1t /volume1/homes/guy/BackupWWW/RPi-PiHole/var/log/SBFSPOT/Zon-Spot*.csv | /bin/sed q))
var=$(echo $string | awk -F";" '{print $1,$2,$3,$4,$5,$6,$7,$8,$9}')
set -- $var
oost=$8
west=$9
var=$(echo $oost | awk -F"," '{print $1}')
set -- $var
oostint=$1
var=$(echo $west | awk -F"," '{print $1}')
set -- $var
westint=$1
sum=$((oostint + westint))
sum=0
fi
DOMOTICZ=`curl -s --connect-timeout 2 --max-time 5 "http://127.0.0.1:8084/json.htm?type=command¶m=udevice&idx=412&nvalue=0&svalue=$sum"`
STATUS=`echo $DOMOTICZ | jq -r '.status'`
if [ "$STATUS" == "OK" ] ; then
exit
sleep 5
STATUS2=`echo $DOMOTICZ | jq -r '.status'`
if [ "$STATUS2" == "OK" ] ; then
exit
sleep 5
STATUS3=`echo $DOMOTICZ | jq -r '.status'`
if [ "$STATUS3" == "OK" ] ; then
exit
curl -s --connect-timeout 2 --max-time 5 --data-urlencode "text=Domoticz Bad - Restarting" --data "silent=false" http://127.0.0.1/secure/telegram.php
NOW=$(date +"%Y-%m-%d_%H%M%S")
cp /volume1/appstore/domoticz/var/domoticz.log /volume1/files/temp/domoticz-$NOW.txt
sudo /var/packages/domoticz/scripts/start-stop-status stop
sleep 5
sudo killall domoticz
sudo killall pass2php.php
sudo killall /usr/local/domoticz/bin/domoticz
sleep 12
sudo /var/packages/domoticz/scripts/start-stop-status start
fi
fi
fi
sanderl
Log file overloads me with:
- Spoiler: show
RonB
I also have the error: Serial port closed. My NAS is the 214play with the RFXCOM transceiver on /dev/ttyUSB0. The error occurs with both, the stable and the beta release. The stable release crashes the webserver. The Beta release ignores the error but Domoticz logs the error every 30 seconds. I've tried the 1005, 1006a but also the 250 and the 251 frmware versions. All with the same result.
Any Ideas on how to solve this?
Regards, Ronald
Regards, Ronald
RonB
Hi Gizmocuz,
Thank you for your response. I never applied for mydomoticz, and it is not enabled in the settings.
Any other ideas?
Regards, Ronald
Any other ideas?
Regards, Ronald
- gizmocuz
@Ron, sorry, i reacted on another post from someone else.
This thread is too diverse, everyone seems to put problems in here that are not specific for synology in here as well.
Gravityz
- Domoticz version: 2025.1
It wolud be great if Jumbotroll also makes a homebridge package voor synology.
might be to much to ask because of all the different platforms
I know there is a docker image but docker does not run on most synologies
- jumbotroll
One day perhaps, when I have too much free timeGravityz wrote:It wolud be great if Jumbotroll also makes a homebridge package voor synology.
Last edited by jumbotroll on Friday 07 October 2016 16:59, edited 1 time in total.
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Jumbotroll
Gravityz
Yes we appreciate the hard work so we are not gonna ask.
I am up for a new synology (DS716+II)
i am waiting for the right moment to buy it.
These things will never drop in price it seems.
- jumbotroll
New Stable Release Domoticz V3.5837!
Domoticz V3.5837 Stable for Synology DSM 6.x
OpenZWave 1.4.2222
http://www.jadahl.com/domoticz_stable_6/
Big Thank's to Gizmocuz!
OpenZWave 1.4.2222
Last edited by jumbotroll on Sunday 30 October 2016 11:31, edited 1 time in total.
Jumbotroll
Jumbotroll
Gravityz
great.
will try it out as soon as i have my new nas
i am still on 5019 which seems extremely stable so i8 do not know if upgrading will give me any benefits(or trouble)
- jorik
- Domoticz version: 3.5877
Thanks Jumbotroll! I bought a Fibaro FGS223 and it is now recognized by the latest Domoticz running on my DS411+II.jumbotroll wrote:New Stable Release Domoticz V3.5837!
OpenZWave 1.4.2222
BTW, do you have any idea why I am unable to add your package repository? I keep getting "invalid location", when using
(I also tried without trailing slash)
Manually installing works fine and other sources also work fine, e.g. I could add this one without issues:
http://isulnara.com/synology/
- jumbotroll
I don't know why you not can add my package repository, It's working for me and there is only one another reporting this problem.jorik wrote:Thanks Jumbotroll! I bought a Fibaro FGS223 and it is now recognized by the latest Domoticz running on my DS411+II.jumbotroll wrote:New Stable Release Domoticz V3.5837!
OpenZWave 1.4.2222
Jumbotroll
Jumbotroll
- jorik
Ok, thanks for the quick reply! Could you tell me how you configured your spk server? Do you use SPKSS from jdel? Maybe I can perform some testing with my own server if I can replicate the issue. E.g. I also cannot add http://packages.jdel.org/. I was wondering if it could have anything to do with certificates and newer DSM versions that check certificates when adding a new source or so.
- jumbotroll
Yes I use http://packages.jdel.org SPKSS server and add all new NAS models manually in conf file.jorik wrote:Ok, thanks for the quick reply! Could you tell me how you configured your spk server? Do you use SPKSS from jdel? Maybe I can perform some testing with my own server if I can replicate the issue. E.g. I also cannot add http://packages.jdel.org/. I was wondering if it could have anything to do with certificates and newer DSM versions that check certificates when adding a new source or so.
In package center I allow: Yes I want to see beta versions! and in Trust Level Any Publisher.
Jumbotroll
Jumbotroll
Jelmer
Thanks jumbotroll for compiling these simple packages.
I just started with domoticz on my synology 212 and it was a real struggle to add some neo coolcam PIR to the system. My very first node on the network controlled with a aeotec z-stick gen 5.
Everything is working well now, the controller is using the cdc-acm.ko driver (already in synology OS), why are you packaging the cp210x.ko, looks like it isnt used.
However, maybe it should... because I have 1 problem with the whole setup, I can not make any changes to the controller or the nodes, for example the network key on the controller, or the LUX report values on the neo coolcam PIR. When I hit apply, it show a red box with a error message (Problem updating node configuration!) and Domoticz crashes. Nothing to see in the logging.
Restart domoticz and everything works fine again, however there are unfortunately no changes applied.
Any idea?
Any idea?
