Moon phase
Derik
Re: Moon phase
Post by Derik »
@ wizjos,
Thanks for the support
I do not understand the uservariable..
Is this correct?
Or what type do i need?
And this is ok?
wizjos
Re: Moon phase
Post by wizjos »
Derik wrote:@ wizjos,
Is this correct?
It looks OK to me (except that my uservar is of type Time).
The uservar is a helper in determining if an update from WU is allowed. WU only lets you poll 10 times in an hour. I found that the script was running too many times in an hour. So with some help from the wiki (http://www.domoticz.com/wiki/Smart_Lua_ ... _Light_Off) I made a check that, when WU has been polled, updates the uservar with the current time (again, this is purely cosmetic).
By updating the uservar the 'lastupdated' property of this uservar is set. This is a Domoticz internal property. (see line 74: commandArray['Variable:'..checkvar]=time.hour..":"..time.min). Each time the value of the uservar changes this property is set by Domoticz to the current date and time (See the column 'Laatste aanpassing' in your picture).
When the script runs again this 'lastupdated' property is checked (line 60: if (may_update(checkvar,checktime)==true) ).
The function may_update checks the difference between the current time and the time the uservar was last updated. If this difference is 3600 seconds the script allows an other update.
I see you've created a uservar of type Text and set the value to 3600. That's OK, but the value 3600 is not important...
Derik wrote:And this is ok?
As far as I can see it is. Be a bit more carefull with displaying your API key by the way!
I hope this helps!
alexsh1
Domoticz version: v3.8975
Re: Moon phase
Post by alexsh1 »
wizjos wrote:
alexsh1 wrote:Good work @ wizjos!
Is your moon icon changing according to the moon phase? Very nice - now I'd like to implement it too :D
I can confirm it is 8-)
Can you enlighten me please? How did you do that? I must admit I am a complete noob when it comes to interface and icons in Domoticz.
Derik
Re: Moon phase
Post by Derik »
mmm Not working...
What can be the dombo error /mistake that i make?
Derik
Re: Moon phase
Post by Derik »
got him:
shame... did not not have activated the srcipt funtion:
Only i think i changed the rise and set, is that correct??
And will you please tell me how you make the changing button with a moon icon...
LouiS22
Re: Moon phase
Post by LouiS22 »
Brillinat, just two questions:
1. does anyone have the neat moon icon package?
2. according to the log the scripts runs in every minute. Is that normal? (I've not changed the 3600 value, so it's a bit odd for me).
Derik
Re: Moon phase
Post by Derik »
runs every minute ..
Because it is a lua time script...
should be great when this can be adjustable
Derik
Re: Moon phase
Post by Derik »
Should it not be better/nicer to us for rise and set custom sensors, with icons?
Rise:
https://www.google.nl/search?q=moonrise ... 0Q_AUIBigB
Set:
https://www.google.nl/search?q=moonrise ... &q=moonset
I cannot make this, it is just a idea
Derik
Re: Moon phase
Post by Derik »
get a warning from wu..
Derik
Re: Moon phase
Post by Derik »
other error:
2016-10-29 22:00:00.906 LUA: Moonrise:	6:46
2016-10-29 22:00:00.906 LUA: Moonset:	18:08
2016-10-29 22:00:00.906 LUA: Percent:	1%
2016-10-29 22:00:00.906 LUA: Age:	29
2016-10-29 22:00:10.311 Error: EventSystem: Warning!, lua script /home/pi/domoticz/scripts/lua/script_time_maan.lua has been running for more than 10 seconds
2016-10-29 22:00:02.892 (D.M.: RFLink) Temp (OregonV1)
2016-10-29 22:00:15.721 Hardware Monitor: Fetching data (System sensors)
LouiS22
Re: Moon phase
Post by LouiS22 »
Derik wrote:get a warning from wu..
That's why I tried to refer with my post above. IMHO the script is buggy in a way as it shouldn't run in every minute - that's 60 request from WU in an hour.
Derik
Re: Moon phase
Post by Derik »
Perhaps someonebcab make this script working as a lua with a crontab.... In steat op lua time
alexsh1
Re: Moon phase
Post by alexsh1 »
LouiS22 wrote:Brillinat, just two questions:
You have to set it up according to your needs. Just think - why would need to know a moon phase every minute? I have my script (above) running every 10 minutes or so. It generates only 6 requests per hour or 144 per day. I think running it one an hour would not hurt either.
alexsh1
Re: Moon phase
Post by alexsh1 »
Derik wrote:other error:
This is not a bug, but happens occasionally due to internet connection issue or a delayed reply from the weather server.
Derik
Re: Moon phase
Post by Derik »
dear i did set time to 4800 only i still get a warning..:
Or can i set the time of the lua script set to a other time to?
Derik
Re: Moon phase
Post by Derik »
Strange thing happend
I did not make a change..:
Only the script is not working after a update from yesterday...
edit:
My error:
2016-10-31 19:03:00.797 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_maan.lua: /home/pi/domoticz/scripts/lua/script_time_maan.lua:148: attempt to concatenate global 'moonPhaseIcon' (a nil value)
2016-10-31 19:04:00.519 Error: Webserver: File '/images/test.png': No such file or directory (2)
2016-10-31 19:04:00.980 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_maan.lua: /home/pi/domoticz/scripts/lua/script_time_maan.lua:148: attempt to concatenate global 'moonPhaseIcon' (a nil value)
2016-10-31 19:05:00.545 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_maan.lua: /home/pi/domoticz/scripts/lua/script_time_maan.lua:148: attempt to concatenate global 'moonPhaseIcon' (a nil value)
2016-10-31 19:06:00.916 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_maan.lua: /home/pi/domoticz/scripts/lua/script_time_maan.lua:148: attempt to concatenate global 'moonPhaseIcon' (a nil value)
2016-10-31 19:07:01.019 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_maan.lua: /home/pi/domoticz/scripts/lua/script_time_maan.lua:148: attempt to concatenate global 'moonPhaseIcon' (a nil value)
2016-10-31 19:08:00.677 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_maan.lua: /home/pi/domoticz/scripts/lua/script_time_maan.lua:148: attempt to concatenate global 'moonPhaseIcon' (a nil value)
Derik
Re: Moon phase
Post by Derik »
did make no change to anything
Only a update..
working again...:-)
Only in the log errors..
alexsh1
Re: Moon phase
Post by alexsh1 »
Derik wrote: Only the script is not working after a update from yesterday...
Version 3.5837 (October 30th 2016)
- Fixed: Blockly/Lua, FOR and RANDOM are now again in minutes
Additionally, please see this http://domoticz.com/forum/viewtopic.php?f=3&t=13942
Some people experience issues with the latest beta
Derik
Re: Moon phase
Post by Derik »
mmm'
The link to the other forum is not working..
Still my calls from wu are not enough...
Round 16.00 are my calls gone...
Is there a solution to make the calls not every minute, but 2 or 3 minutes?
Love this option
and the Moon picto's??
cyberclwn
Domoticz version: 2024.4
Re: Moon phase
Post by cyberclwn »
I just tried use this script, and i almost got it working but i also got the error:
EventSystem: in /home/pi/domoticz/scripts/lua/script_time_moon.lua: /home/pi/domoticz/scripts/lua/script_time_moon.lua:82: attempt to concatenate global 'moonriseMinute' (a nil value).
And i guess it is because the reply i get from WU doesn't contain the moonrise information:
  "response": {
  "version":"0.1",
  "termsofService":"http://www.wunderground.com/weather/api/d/terms.html",
  "features": {
  "astronomy": 1
                ,       "moon_phase": {
                "percentIlluminated":"52",
                "ageOfMoon":"22",
                "phaseofMoon":"Waning Gibbous",
                "hemisphere":"North",
                "current_time": {
                "hour":"21",
                "minute":"24"
                "sunrise": {
                "hour":"8",
                "minute":"42"
                "sunset": {
                "hour":"16",
                "minute":"27"
                "moonrise": {
                "hour":"",
                "minute":""
                "moonset": {
                "hour":"12",
                "minute":"34"
        "sun_phase": {
                "sunrise": {
                "hour":"8",
                "minute":"42"
                "sunset": {
                "hour":"16",
                "minute":"27"
So there is probably no error in the lua-script, but for some reason WU is not supplying all the information that is expected by the lua-script.
On the website of WU it says:
Dec. 20, 2016 	Opkomst 			Ondergang
Maan 			Geen maanopkomst 	12:34 PM CET
So i guess we don't have a moon tonight :)
3xPi 2B (Domoticz "live", Domoticz "sandbox", PhotoFrame)
RFXCom433(E), KaKu, Oregon Scientific, Keyes 2-relay, Logitech Media Server, MiLight, Smartwares heating controller(2x), IR Send/Receive, Keyes PIR, XH-M131 DuskSensor, DHT22/11
