FGMS-001 ZWave plus
juankar
Domoticz version: 4.
FGMS-001 ZWave plus
Post by juankar »
Hello
Has anybody tested the new Fibaro sensors (ZWave plus)?
Bye
Egregius
Domoticz version: v2024.7
Re: FGMS-001 ZWave plus
Post by Egregius »
Is the FGMS-001 Zwave Plus device? I thought they were classic zwave.
juankar
Post by juankar »
No, there is a new sensor zwave plus: FGMS-001 ZW5. I've seen it in same domotics shop (google FGMS-001 Z-W5 and you'll find them)
And it appears in zwavealliance
http://products.z-wavealliance.org/products/1146
Bye.
Egregius
Post by Egregius »
You're topic title should have been "FGMS-001 ZW5" then :mrgreen:
juankar
Post by juankar »
Yes, you're right. :oops:
course66
Domoticz version: V2.3202
Post by course66 »
Hi jaunkar,
I'm also trying to use the motion sensor model FGMS-001(bought on http://www.amazon.it/gp/product/B00JHHN ... ge_o02_s00) but I'm having troubles... see
http://www.domoticz.com/forum/viewtopic ... 24&t=11000
ciao,
gabriele
thazar
Post by thazar »
I am new user of domoticz, I just installed it last week-end on Raspberry PI 3.
I use a SIGMA DESIGNS Dongle Z-Wave Plus USB, and try to use the new Fibaro Motion Sensor FGMS-001 ZW5. It is the only device I have, wanted to test one before buying more devices.
The device is not recognized correctly, and I can't change parameters (only 1 displayed).
I think that the device is not yet supported by domoticz, or maybe I miss install of device (I am newbie in domotic).
Is there a way for me to make it works (change of configuration file ?) ?
Or is there anything I can provide to help team for support of the device by domoticz ?
Is there a way to change parameters of device ( by OpenZWave Control Panel maybe ? ) ?
juankar
Post by juankar »
Hello
Devices using batteries are sleeping most of the tme. You must wait for a time when they awake Domoticz read and set config parameters. Fibaro take 7200 seconds (2 hours) to wake up. After that Domoticz will show parameters.
You can forcé awake with inclusión button of sensor (press three times).
I will this help you.
Bye
richardtrip
Re: RE: Re: FGMS-001 ZWave plus
Post by richardtrip »
thazar wrote:Hello,
You need to add the device ID to an XML file to make it work. After that restart domoticz, exclude the device and include again. See this topic: http://www.domoticz.com/forum/viewtopic.php?t=3814
Verstuurd vanaf mijn SM-G925F met Tapatalk
thazar
Post by thazar »
Works fine, thanks a lot
Kerneldomoticz
Domoticz version: 3.5248
Post by Kerneldomoticz »
So basically it is the same config xml file as the previous version and you only need to add the ID in the specific manufacturer file ? (Sorry for the noob question i'm 200% newbie)
jorgitold
Domoticz version: 3.5839
Post by jorgitold »
works all devices but always in motion sensor ON, never again oFF
including and excluding node several times, but no motion is detected, the sensor if the LED flashes and detects the movement but never displayed in domoticz
any ideas?
juankar
Post by juankar »
Have you look the log? Log files can give us some important data.
Tamagnun
Post by Tamagnun »
Can someone confirm that using FGMS-001 Z5 V3.2 the temperature is correctly read? In the official compatibility list it is reported that using v3.2 sensor the temperature reading doesn't work...
Thank you for your experience.
Tamagnun
Post by Tamagnun »
I answer to myself, maybe someone may appreciate this feedback... with Domoticz Rel. 3.5877 the FGMS-001 GEN5 the temperature is properly returned (sometimes the temperature device doesn't appear at the include time but one/two days after), unfortunately two other issues are present:
- tamper status is returned on the same device referred to motion sensor (device 000xx00 or 000xx35, depending of nodes fw version), the device 000xx28 that reports the tamper (vibration) status on FGMS-001 Gen3 never changes on Gen5 devices
- It is NOT possible to update parameters #42, #64 and #66 (related to lux and temperature report and offset) on three different Fibaro FGMS001 sensors (this issue also on Gen3 motion sensor)
Tamagnun
Post by Tamagnun »
Last UPDATE: using the attached configuration file that I've preparred to manage properly the Gen5 version of FGMS-001, the tamper status is properly reported throught the device 000xx35.
Node 1 (your ZWave or ZWave+ controller) needs to be added to the group 1, 2 and 5 in order to have all the values properly sent to Domoticz.
fgmszw5.xml
FGMS-001 Gen5 ZWave+ XML configuration file
(17.42 KiB) Downloaded 274 times
ropske
Domoticz version: V3_8394
Post by ropske »
thanks Tamagnun,
i'm having the same problem but with my Wall plug FGWPE-102 ZW5
i think i will also need to make a seperate xml file.
How did you know the tamper is on 0x28 and motion on 0x35? is this somewhere discribed?
Thanks a lot!
ropske
Post by ropske »
nevermind, just found the manuals where it is discribed :p
seems i will need to make a new xml file also
Tamagnun
Post by Tamagnun »
Well done!! ;)
kman
Post by kman »
Hi Tamagnun,
Thanks for the details and the xml file.
Currently I have included the controller to Group 1, Group 4, Group 5 of Fibaro Motion (v3.2)
After including your above suggestions, in my case :
- motion is not detected till I add the controller to Group 4.
- Motion is not detected in Group 2.
- Group 4 (is for backward compatibility for Motion) and Group 5 (backward compatibility for Tamper)
But my controller is Aeon Zstick Gen5 USB controller - which is zwave plus version - so, it should have responded to motion on Group 2? which controller are you using?
Now coming to motion detection that is happening on Group 4, on every motion detection, I also see Alarm Level, Alarm Type, and Burglar. Any comments?
Details of my installation:
Domoticz version: 2.3266
OpenZwave version: 1.3492
Fibaro Motion: v3.2
controller: aeon zstick gen5 usb
thanks.
