New RFLink firmware (R44) now available!
- Stuntteam
Brand new RFLink Gateway firmware adds support for Ikea Ansluta, Philips Living Colors Gen1, MySensors devices and has "Mini" GPIO.
For Ansluta or Living Colors you will need a CC2500 module. Details on how to connect these modules are on the Wiring details page.
Changelog:
R44:
- New Device: Ikea Ansluta (2.4 Ghz device, CC2500 transceiver required)
- New Device: Philips Living Colors Generation 1 (2.4 Ghz device, CC2500 transceiver required)
- New Device: Friedland DC44
- New Device: Warema EWFS shutters and awnings
- New Device: Bosch DID09T951, Bosch DID09T950 and compatible ventilation units
- New Device: Siemens SF-01 and compatible ventilation units
- New Device: Wave Design SF-01 and compatible ventilation units
- New Device: Visonic MCT-302 open and close signal
- New Device: Ningbo KD-205-1 switch set
- New Device: Steffen Power Switch (1204380 3M)
- New Device: Bresser weather sensor
- New Device: RFTech 210TX weather sensor
- New Feature: Bluetooth LE Advertisement packet sniffing *experimental* (NRF24L01 required, needs to be wired for MiLight)
- New Feature: MySensors packet sniffing *experimental* (NRF24L01 required, needs to be wired for MiLight)
- New Device: MySensors temperature and humidity devices (more types to follow) (NRF24L01 required, needs to be wired for MiLight)
- Fixed: Improved OWL CM130 recognition
- Fixed: Revolt power reporting corrected
- Fixed: RFmeter values presented in hexadecimal
- Fixed: Improved Baldr signal recognition
- Added: Friedland PIR checksum calculation
- Added: GPIO 4 input and 4 output pins can be used as on/off or push button devices
Changelog:
R44:
Re: New RFLink firmware (R44) now available!
This rocks !
Ble show Xiaomi MI Scale packets !
Have to test :
Parrot Flower Power/Pot
Sony Smart Band 2
Have to test :
Sony Smart Band 2
http://domo-attitude.fr
- remb0
great! nice work! keep up the good work!
Thanks! Can you remind me how to update directly from rpi? Thanks again...
Inviato da Tapatalk
Inviato da Tapatalk
- Domoticz version: BETA
great guys... Cannot buy the sensors with the speed you implement ...
- thecosmicgate
- Domoticz version: newest
Thnx again Bosch works on rflink but at the moment not within domoticz
It's nice to be important, but it's more important to be nice
Scooter ;)
Scooter ;)
- Westcott
I'm now getting this message a few times per hour, never saw it before -
Error: RFLink: Error/Unknown command received!...
Nice work.
Verstuurd vanaf mijn SM-G920F met Tapatalk
Mhh strange, my log is also getting filled with these. Before the upgrade i had no issues.Westcott wrote:Thanks!
Seems to happen every minute:
2016-10-27 22:10:09.171 (rflink) Temp + Humidity (Vochtigheid)
2016-10-27 22:10:14.927 Hardware Monitor: Fetching data (System sensors)
2016-10-27 22:10:39.409 Error: RFLink: Error/Unknown command received!...
2016-10-27 22:10:44.965 Hardware Monitor: Fetching data (System sensors)
- Stuntteam
redownload and reflash the file if you see those errors.
I tried that, but I also still get the errors. I've reverted back to R43 and I don't get that error in the logs anymore.
- Westcott
What you need is Version: 44.8
Are you still on build 7?
Ah, I was on build 7, that might be it.
Fixed it for me, also was on build 7, now on 8. Thanks
- bizziebis
- Domoticz version: 3.8805
How can I use Philips Living Colors Generation 1? I have a CC2500 module attached to the RFLink and it's activated. But I don't see anything when I press the remote..
Edit:
I messed up the wiring. Now I see the remote when I press it, only sending it back to the lamp doesn't work.
Edit:
- Domoticz version: Latest
Since upgrading to RFLink VER=1.1;REV=44;BUILD=08;
I have problems with my MiLight bulb, they don't respond anymore.
If i reflash back to R43 everything starts working again.
This is the Domoticz log;
The settings i did within the flash tool;
Any clue what this could be?
2016-11-02 19:05:00.288 User: Admin initiated a switch command (9/Bedroom Light/Set Level)
2016-11-02 19:05:00.289 RFLink Sending: 10;MiLightv1;0169;01;00ad;ON
2016-11-02 19:05:00.438 Error: RFLink: Error/Unknown command received!...
2016-11-02 19:05:00.439 RFLink Sending: 10;MiLightv1;0169;01;00ad;BRIGHT
2016-11-02 19:05:00.514 Error: RFLink: Error/Unknown command received!...
2016-11-02 19:05:00.515 (RFLink) Lighting Limitless/Applamp (Bedroom Light)
20;04;STATUS;setRF433=ON;setNodoNRF=OFF;setMilight=ON;setLivingColors=OFF;setAnsluta=OFF;setGPIO=OFF;setBLE=OFF;setMysensors=ON;
10;setnodonrf=off;
20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R44;
20;01;MySensors=ON;
10;setMilight=on;
20;01;MiLight=ON;
10;setMySensors=on;
20;01;MySensors=ON;
You have to choose between milight or mysensors but not both on the same time.
For the moment
For the moment
- Stuntteam
Next release will have a solution so that you can use both
Same problem with everything off except MiLight
20;03;VER=1.1;REV=44;BUILD=08;
10;status;
10;SetMySensors=off;
20;01;MiLight=ON;
20;02;Alecto V4;ID=5e68;TEMP=00bf;
10;setBLE=off;
20;01;MiLight=ON;
10;setMilight=on;
20;01;MiLight=ON;
10;setnodonrf=off;
10;setLivingColors=off;
10;setBLE=off;
20;01;Alecto V4;ID=5e68;TEMP=00bf;
10;setGPIO=off;
2016-11-02 20:50:04.324 User: Admin initiated a switch command (9/Bedroom Light/Set Level)
2016-11-02 20:50:04.326 RFLink Sending: 10;MiLightv1;0169;01;0023;ON
2016-11-02 20:50:04.408 Error: RFLink: Error/Unknown command received!...
2016-11-02 20:50:04.409 RFLink Sending: 10;MiLightv1;0169;01;0023;BRIGHT
2016-11-02 20:50:04.485 Error: RFLink: Error/Unknown command received!...
Hi, how do i control the living colors generation 1 from within domoticz?
I have the rflink with a cc2500 attached to it with firmware r44.
