notification when a scene start
guantolento
Domoticz version: LastBeta
Post by guantolento »
good evening everyone. I would like to know if you can be notified when a scene is active. having some scene that are activated in automatic mode at specific times, receiving the notification would have the assurance that the system works properly. can someone help me ?
Master (pi3) - MB sensors + Dummy + Sysfs gpio + 1 NodOn MSP-3 + 1 Aeotec DSB28 Energy Meter + 3 Danfoss RS Room + 7 Danfoss Z Thermostat + 1 Swiid Inter + 9 FGS222
Slave01 (pi2) - MB sensors + Dummy + Weather Underground + 2 FGS223 + 1 FGWPE/F
Egregius
Domoticz version: v2024.7
Re: notification when a scene start
Post by Egregius »
Go scripting, then you control everything you want ;)
Derik
Post by Derik »
Egregius wrote:Go scripting, then you control everything you want ;)
Scipting is a hard part [ for me ].. Do you have a simple how to...
Or a good/simple start..
safi78
Post by safi78 »
I just tried this with LUA:
if (devicechanged ["scene:MyScene"] == "On") then
        commandArray['SendNotification']="MyScene On"
which does not work.
Alternative, add a dummy switch unique for that scene to your scene and add notifications for that?
homebridge, rfxcom, zwave, nest, applamp, hue, debian, apple, mysensors, netatmo, fibaro, synology, foscam, otherz
safi78
Post by safi78 »
Or even better, hook up a telegram bot to domoticz :)
Scenes have an "On"-action, where you can call the telegram-api and send the notification through there?
I don't think you can 'loop-back' a notification by calling the notification system with the domoticz-api itself hehe. (<- would work if it was implemented lol)
Derik
Post by Derik »
safi78 wrote:Or even better, hook up a telegram bot to domoticz :)
Telegram bot.. nice..
Only 1 problem
You can not send a message to a other person...
That is not the best option..
Looks great when you can choose with the bot for different people where you can sent the message to...
safi78
Post by safi78 »
Suggestion (not tested though):
Start a telegram group-chat, add the bot to that chat and use that chat_id?
Could work?
safi78
Post by safi78 »
Derik
Post by Derik »
what a great option like to me.
I can send message from the bot to separate people
To my wife 2 Wednesday.. Set the garbage outside
To my kids close the door
To my self xx
To x .. y
To my wife sex...
etc
And then in the notification area from a device..
safi78
Post by safi78 »
You could do that theoretically if you know the chat_id's and script it?
safi78
Post by safi78 »
Don't know how you are going to implement the 'sex' thing with your wife through domoticz though, but hey, why not.
You could just use telegram for that in the way it was intended. Send a message ;)
Derik
Post by Derik »
I mean this part:
I do have the bot working only on this place the bot send to one adres....
When i can set the bot here to different people should be great..
safi78
Post by safi78 »
Like I said, a groupchat would be the way to go. Or script it.
guantolento
but, can you explain me how to ? just a little example if you can.
Egregius
Post by Egregius »
Derik wrote: Only 1 problem
Not correct.
As long as that 'other person' sends a message to the bot you can find the chat id.
Something goes when you add the bot to a group or a channel.
That way I sent Telegram messages to my wife, to myself and to both in a channel.
Well, the scenes have a own LUA table now, so it's possible to detect changes in scenes and use that as a base.
Must be easy to add to my pass2php script, I don't use scenes as I create them my own completely in a script.
Sending a message in that script is as simple as
telegram('this is the message','receiver');
guantolento
hi guys,
i tried with this script lua but don't work.
if devicechanged['Scene:Spegni Luci Zona Notte'] == 'On' then
commandArray['SendNotification'] = 'Domoticz Email#Spegni Luci Zona Notte#[email protected]'
if i use this script mail arrived, but continuos mail...
if devicechanged['Bagno Piccolo Specchiera - S1'] == 'On' then
commandArray['SendNotification'] = 'Domoticz Cambio Stato#Bagno Piccolo Specchiera ON#[email protected]'
someone can tell me why ?
guantolento
I solved this issue with a telegram action when the scene in on.
Inviato dal mio GT-I9301I utilizzando Tapatalk
madrian
Post by madrian »
Anyone knows why
(devicechanged['Scene:...]) is not working in LUA scripts?
astrapowerrr
Post by astrapowerrr »
I just updated to the beta version and now when any scene is started I get notification.
For example: I have set 2 notification 1 for opening and closing air ventilation and one if pond temp gets above 10 degrees. Both working fine!!
But now when I use the scene I’m home, or good night, or close curtains, etc...
The notification says my pond is above 10 degrees and it gives a notification of the air vent position(closed or open at the time).
So when I’m not at home and with sunset my curtains are closing(scene) I get notification my airvent is open. :oops: :?
So it notifies the status, but I want to be notified when it changes....
Someone familiar with this?
Could this be related ?
viewtopic.php?t=17767
