Domotiz not ready for latest Debian?!? Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
renerene
Post by renerene »
/domoticz/domoticz: /lib/x86_64-linux-gnu/libcrypto.so.1.1: version `OPENSSL_1_1_1' not found (required by /home/domoticz)
come on...
Did a fresh install, latest debian (12) on proxmox VM NUC, but now you teling me domoticz needs older OS?
Installed OPENSSL 1.1, but still no good. [edit: apparently not]
Please update wiki and tell us which Ubuntu/Debian version to use
Domoticz version: 2025.1
Re: Domotiz not ready for latest Debian?!?
It works but you need to install libssl1.1 as that is replaced by libssl3
There are other topics about this, a little search will find these. Or use the docker environment to get rid of software requirements.
renerene
Re: Domotiz not ready for latest Debian?!? -libssl1.1
Post by renerene »
no thank you, I'm just new in the proxmox matter, and there is not enough will to struglle through Docker USB matter
attempts to install 1.1: no luck
 wget http://security.debian.org/debian-security/pool/updates/main/o/openssl/libssl1.1_1.1.0l-1~deb9u3_amd64.deb
--2025-01-21 18:00:43--  http://security.debian.org/debian-security/pool/updates/main/o/openssl/libssl1.1_1.1.0l-1~deb9u3_amd64.deb
Resolving security.debian.org (security.debian.org)... 151.101.66.132, 151.101.194.132, 151.101.130.132, ...
Connecting to security.debian.org (security.debian.org)|151.101.66.132|:80... connected.
HTTP request sent, awaiting response... 404 Not Found
2025-01-21 18:00:43 ERROR 404: Not Found.
wget http://security.ubuntu.com/ubuntu/pool/main/o/openssl/libssl1.1_1.1.1l-1ubuntu1.2_amd64.deb
sudo dpkg -i libssl1.1_1.1.1l-1ubuntu1.2_amd64.deb
sudo apt-get install qtbase5-dev qtchooser qt5-qmake qtbase5-dev-tools
sudo dpkg -i synergy_1.14.3-stable.218fa800_ubuntu21_amd64.deb
--2025-01-21 18:03:11--  http://security.ubuntu.com/ubuntu/pool/main/o/openssl/libssl1.1_1.1.1l-1ubuntu1.2_amd64.deb
Resolving security.ubuntu.com (security.ubuntu.com)... 185.125.190.83, 91.189.91.83, 91.189.91.82, ...
Connecting to security.ubuntu.com (security.ubuntu.com)|185.125.190.83|:80... connected.
2025-01-21 18:03:11 ERROR 404: Not Found.
Jan 21 18:12:37 debian domoticz.sh[1101]: /home/sys/domoticz/domoticz: /lib/x86_64-linux-gnu/libcrypto.so.1.1: version `OPENSSL_1_1_1' not found (required by /home/sys/domoticz/domoticz)
unfortunatly, beta version also needs the old openssl 1.1.1
Where can i find this old version libssl1.1.1? and openSSL_1_1_1?
renerene
Post by renerene »
I am quite “surprised” that the default Domoticz installation procedure is outdated and there is not a quick fix. Is docker the new default?
How many new users have already dropped out here?
I used this topic to install libssl1
https://stackoverflow.com/questions/721 ... 4#72633324
The package depends on your hardware architecture as explained in the answer. The latest version can be found here: http://nz2.archive.ubuntu.com/ubuntu/po ... l/?C=M;O=D
I used the amd64 version.
wget http://nz2.archive.ubuntu.com/ubuntu/pool/main/o/openssl/libssl1.1_1.1.1f-1ubuntu2.23_amd64.deb
sudo dpkg -i libssl1.1_1.1.1f-1ubuntu2.23_amd64.deb
renerene
Post by renerene »
yes!
thanks a lot Walter
Truffe13
Domoticz version: 2024.7
Post by Truffe13 »
I had the same issue when trying to install the wiki (pre-built installation - https://wiki.domoticz.com/Linux#Use_pre ... stallation) on Ubuntu Server 24.04.2 LTS
Domoticz needed to have libssl11 AND open ssh 1.1 installed
I solved with the following :
wget http://archive.ubuntu.com/ubuntu/pool/main/o/openssl/libssl1.1_1.1.1f-1ubuntu2.24_amd64.deb
wget http://archive.ubuntu.com/ubuntu/pool/main/o/openssl/openssl_1.1.1f-1ubuntu2.24_amd64.deb
then
sudo dpkg -i libssl1.1_1.1.1f-1ubuntu2.24_amd64.deb
sudo dpkg -i openssl_1.1.1f-1ubuntu2.24_amd64.deb
Then install domoticz (version 2024.7)
sudo bash -c "$(curl -sSfL https://install.domoticz.com)"
Hope it will help.
Dave21w
Domoticz version: Stable
Post by Dave21w »
Although I don't disagree with your comments I think you were a little harsh. Domoticz is a fantastic piece of software which is given away for free and alot of people give up their own time to support and make it a good as possible. I for one am very greatful for this and the support from the forum, give them a little latitude when things don't go right for you straight away.
Thanks Guys.
gizmocuz
Post by gizmocuz »
The problem is with users using the old Debian version, they use a different SSL library.
Actually, I find the problem in the OpenSSL library as it seems it is not backwards compatible
We have this issue for quite some time, and it will be addressed with the upcoming stable version, but this will users require to upgrade their system.
Another option, just use the docker install, there are no dependencies! (Thats why they invented it)
ChriWo
Domoticz version: 2022.1
Post by ChriWo »
I had the same problem with Debian 12.x I solved it like this:
First get ssl 1.1
wget http://security.debian.org/debian-security/pool/updates/main/o/openssl/libssl1.1_1.1.1w-0+deb11u2_amd64.deb
Install ssl 1.1
sudo dpkg -i libssl1.1_1.1.1w-0+deb11u2_amd64.deb
after that install Domoticz
nonecz
Post by nonecz »
OH I got it,
1. get the package from http://security.debian.org/debian-secur ... o/openssl/
wget http://security.debian.org/debian-secur ... _amd64.deb
2. install
sudo dpkg -i libssl1.1_1.1.1w-0+deb11u3_amd64.deb
installation fixed. Thank you! This controller looks alive, thanks good.
