I am looking for a way to use the hue dimmer / switch in dzvents. Until now nothing can be found. There are 4 buttons that can be pressed short and long. I have not been able to find how to use this in dzVents. Is there anyone who has information about it.
Thankx,
Peter
Philips hue dimmer switch [Solved]
- waaren
Re: Philips hue dimmer switch
This Hue device was implemented in domoticz in version V.11454 as a selector switch with 9 levels. (see below)kroonp wrote: Thursday 06 August 2020 15:17 I am looking for a way to use the hue dimmer / switch in dzvents. Until now nothing can be found. There are 4 buttons that can be pressed short and long. I have not been able to find how to use this in dzVents. Is there anyone who has information about it.
Thankx,
Peter
NB. Depending on the set poll interval for the Hue hardware module in domoticz there can be delay between pressing the button and the event triggered.
A dzVents script to make use of the selector could look like
return
on =
devices =
'Hue twilight', -- change to name of your Hue selector / dimmerswitch
logging =
level = domoticz.LOG_DEBUG,
marker = 'Hue dimmer / selector',
execute = function(dz, item)
dz.log('Device ' .. item.name .. ' updated. Last level was ' .. item.lastLevel .. '; new level is ' .. item.level .. ' (' .. item.levelName .. ')', dz.LOG_DEBUG)
actions =
['Button 1 long'] = function() return '1L' end,
['Button 2 long'] = function() return '2L' end,
['Button 3 long'] = function() return '3L' end,
['Button 4 long'] = function() return '4L' end,
['Button 1 short'] = function() return '1S' end,
['Button 2 short'] = function() return '2S' end,
['Button 3 short'] = function() return '3S' end,
['Button 4 short'] = function() return '4S' end,
['Off'] = function() return 'Off' end,
dz.log('Short name for ' .. item.levelName .. ' ==>> ' .. actions[item.levelName](),LOG_DEBUG)
}Debian buster, bullseye on RPI-4, Intel NUC.
kroonp
Thank you for the reply. Unfortunately I do not yet understand how I can switch on a device with for example -button1 short-. But that is due to my inconsideration. I keep trying.
- waaren
Hope this will help you understandkroonp wrote: Friday 07 August 2020 0:40 Thank you for the reply. Unfortunately I do not yet understand how I can switch on a device with for example -button1 short-. But that is due to my inconsideration. I keep trying.
return
on =
devices =
logging =
deviceToSwitch = dz.devices('testDevice') -- change to name of device to switch when button 1 is pressed short
actions =
if item.levelName == 'Button 1 short' then
deviceToSwitch.switchOn()
kroonp
Re: Philips hue dimmer switch [Solved]
Thank you very much, I get it now. I have adjusted my script and it now works the way I intended it to. Thanks again and have a nice weekend.
Obelix
Is there also a possibility to use the switch for 'dynamic' dimming like the Hue dimmer switch can do using the Hue AP?
So press and hold button 2 to have dynamic brighter light?
Now I can also press longer to add a delta to the status.
I would like dynamic dimm + and -.
Is that possible?
Is that possible?
- waaren
I don't think this is possible other then with native Hue hub.
Obelix
That's too bad,
thanks!
thanks!
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
