Hi.
I use System Alive Checker (Ping).
Below example from Domoticz Wiki:
Simple question: is there any way with script or better w json url to change "Sauron" device to other value ?
Why I need that ? My Mikrotik router has a backup LTE ISP uplink with dynamic IP address. I wish to send obtained IP address to domoticz every time it is changed.
Any hint ?
Best regards to all
System Alive Checker question Topic is solved
- Domoticz version: 2024.7
Re: System Alive Checker question
Change the value from the web ui and check with F12, section network the API call to modify. It could be that part of the url is base64 encoded
This is the url:
http://192.168.2.xxx:8080/json.htm?type=command¶m=pingerupdatenode&idx=<hardware idx>&nodeid=<node ID>&name=<name>&ip=<ip-address>&timeout=5
@Kedi: You have made my day - thx !
"status" : "OK",
"title" : "PingerUpdateNode"
"status" : "OK",
After upgrade of domoticz to Version: 2024.6 (build 16150) it seems to me code is not working any longer. Can someone confirm that ?
BR.
BR.
- Domoticz version: 2024.6
I get lots of false positives with this.
Intel NUC with Ubuntu Server VM (Proxmox),mosquitto(docker),RFXtrx433E,zwavejsUI (docker),Zigbee2mqtt(docker),SMA Hub (docker),Harmony Hub plugin, Kodi plugin,Homebridge(docker)+Google Home,APC UPS,SMA Modbus,Mitsubishi MQTT, Broadlink,Dombus
