Sonoff Touch Topic is solved
- Eddiever
- Domoticz version: 2022.1
Sonoff Touch
I have a Sonoff Touch wall switch. I would like to change it's firmware through ESP Easy. I have been searching but haven't found the right firmware. Due to the fact it is using the 8285 chip instead of 8266.
Does anyone have a suggestion?
mayyam
- Domoticz version: 4.11333
Re: Sonoff Touch
https://1drv.ms/u/s!AjRs7Xpm-jMMg6EYYOO2yP4G3WH2rg
from - http://xbmcnut.blogspot.com/2017/02/how ... touch.html
_______________
- Dell FX-160 / Ubuntu 16.04
- RFLink 433Mhz / NRF 2.4GHz
- 2x Xiaomi Gateway
- different species of ESP8266
- 2x Xiaomi Gateway
- Eddiever
Re: Sonoff Touch
mayyam, thanks. I just flashed it. Now to replace it with the active touch which is in normal use. But do I cut the power or should I just replace the circuitboard with the wiring still alive? Just kidding, always with the power off.
- Eddiever
Re: Sonoff Touch
As I stated before I am very new and trying things out. Flashing worked. I can activate the ligth by hardware switch and from Domoticz. But somehow (I really don't know why) if I switch it manually the status in Domoticz won't change. Used some info from sincze
On action Domoticz:
I could really use some help. Who can?
On action Domoticz:
http://192.168.1.160/control?cmd=GPIO,12,1-
mayyam
Re: Sonoff Touch
That's my config.
And I also use Rules:
on System#Boot do
gpio,12,1
timerSet,1,1
endif
endon
on Rules#Timer=1 do
gpio,12,0
endon
on button#state do
if [button#state]=1
gpio,12,1
endif
endon
on button#state do
if [button#state]=0
gpio,12,0
endif
endon- Attachments
- devices_2_2017-04-23 20_48_50-sonoff_touch_lazienka.png (16.77 KiB) Viewed 7819 times
- devices_1_2017-04-23 20_48_27-sonoff_touch_lazienka.png (15.08 KiB) Viewed 7819 times
_______________
- 2x Xiaomi Gateway
- 2x Xiaomi Gateway
- Eddiever
Re: Sonoff Touch
Sorry mayyam, thought the code was from sincze.
Even if I set it up exactly like your example the state doesn't change within Domoticz. The IDX variable was wrong in my case. In Domoticz it has the value of 3. I changed that in both ESP devices.
From Domoticz: What kind of stupid thing I am overlooking?
mayyam
Re: Sonoff Touch
On ESPEasy, in button device You have to give idx of realay device in domoticz and check "Send data" chceck box.
_______________
- 2x Xiaomi Gateway
- 2x Xiaomi Gateway
- Eddiever
Re: Sonoff Touch
Changed it to 3 but still no state change when manually switched
mayyam
Re: Sonoff Touch
Do You have "Send data" checked?
Also On Config tab: Protocol, Controller IP and Controller Port - do You have right values ?
_______________
- 2x Xiaomi Gateway
- 2x Xiaomi Gateway
mayyam
Re: Sonoff Touch
And the Config tab?
_______________
- 2x Xiaomi Gateway
- 2x Xiaomi Gateway
- Eddiever
Re: Sonoff Touch
The config:
mayyam
Re: Sonoff Touch
If Your Domoticz server is 192.168.1.200, and port is 8080 it looks right to me.
_______________
- 2x Xiaomi Gateway
- 2x Xiaomi Gateway
- Eddiever
Re: Sonoff Touch
My server is indeed on 192.168.1.200 and the port is 8080. Thus it is strange
8080 is the default port, right?
mayyam
Re: Sonoff Touch
Right.
I Have no Domoticz password, so my Controller User and Controller Pass fields are empty, but maybe You have to fill them ?
_______________
- 2x Xiaomi Gateway
- 2x Xiaomi Gateway
- Eddiever
Re: Sonoff Touch
Oh mayyam, how great (and stupid of me). That is it. Username/password. Darn me.
Thank you so much for your quick reply and help!
mayyam
Re: Sonoff Touch
Try Rules. With Rules if Wifi will crash, Sonoff Touch will still work. Also, there is no latency when You switch it manually with Rules.
on button#state do
if [button#state]=1
gpio,12,1
endif
endon
on button#state do
if [button#state]=0
gpio,12,0
endif
endonCode: Select all
on System#Boot do
gpio,12,1
timerSet,1,1
endif
endon
on Rules#Timer=1 do
gpio,12,0
endon
_______________
- 2x Xiaomi Gateway
- 2x Xiaomi Gateway
- Eddiever
Re: Sonoff Touch
I have copied your rules and used them
Great to know Rules in combination with actions if wifi is out. Will dive into that later on.
mayyam
Re: Sonoff Touch
You can also use the GPIO - 13 on the Wifi Status Led on the Hardware settings.
_______________
- 2x Xiaomi Gateway
- 2x Xiaomi Gateway
- Eddiever
Re: Sonoff Touch
Already done that:
on System#Boot do
gpio,12,1
gpio,13,0
timerSet,1,1
endif
endon
on Rules#Timer=1 do
gpio,12,0
gpio,13,1
endon
on button#state do
if [button#state]=1
gpio,12,1
gpio,13,0
endif
endon
on button#state do
if [button#state]=0
gpio,12,0
gpio,13,1
endif
endonWho is online
