I have two Fibaro FGMS001, each has a device for temperature, and another for Lux, with the same node name.
In Blockly there is a choice of devices: Temperature, and Utility/Actual (for Lux)
In Lua, if I use otherdevices_svalues['node-name'] one of the FGMS001 nodes returns its temperature, the other returns its Lux.
Any ideas how to get both nodes to reliably return Lux in Lua?
Getting Fibaro FGMS001 Lux with Lua
- Westcott
- jvdz
- Domoticz version: 4.107
Re: Getting Fibaro FGMS001 Lux with Lua
You should have different devices for Temp/Lux and motion detection, which you can retrieve the data for when you have given them all a unique name.
Did you given all 3 devices the same name?
Jos
Jos
- Westcott
Doh!
I realised that as I was in the shower after posting the stupid question!
Thanks.
Thanks.
