New RFLink firmware available
- Stuntteam
RFlink v1.1 release 36 is now available.
If you have mailed debug data and your device is not implemented yet, then you can be sure that we are still working on it!
Changelog R36:
- Added: RF Environment Optimization System (Thanks: Snips)
- Added: Maclean Energy MCE04 & 07 remote control and switches
- Added: Brel DC90
- Added: Medion MD 16179 doorbell (Receive only)
- Added: Remote 546
- Added: X10 security sensor protocol (a.o. Marmitek)
- Added: Everflourish EMW100 / Cotech EMW100R (Thanks: J)
- Added: Home Easy support for direct dim values
- Added: SelectPlus Black Bell Button (non-A model)
- Added: Silvercrest ian7443 type 10164 R RC202
- Added: Atlantic's security sensors (receive only)
- Added: (initial support for) FAAC TM signals (receive only)
- Added: Oregon Scientific RTGN318
- Added: WT0122 pool thermometer
- Added: GlobalTronics GT-WT-01, GT-WT-02
- Added: Rohrmotor24
- Changed: Removed temperature limits on LaCrosse/TFA
- Changed: Alecto V1 ID split (rolling code & channel number) for wind sensors
- Fixed: Ikea Koppla signal detection
- Fixed: Ikea Koppla dimming
- Fixed: Cresta sensor reporting period when there is low traffic
- Fixed: EMW200 transmit function
- Fixed: Lightwave RF transmit function
- Fixed: UPM/Esic minus temperature handling
- Fixed: OWL CM180 (Big thanks to Snips)
- Fixed: Various Oregon sensor optimizations (Big thanks to Snips)
- Fixed: WS3600 rounding of rain values for precision
- Fixed: WS3600 wind speed only passes one value at a time, Domoticz needs both. RFlink now passes the last know value for the non-received data
- Fixed: Improved Alecto V4 signal detection
- Fixed: Brel motor send command handling
- Fixed: BofuMotor send command handling
- Fixed: Elro Doorbell detection (among others: DB200Z, DB270)
Changelog R36:
- Added: Brel DC90
- Added: Remote 546
Re: New RFLink firmware available
Nice!!! Thanks
Raspberry Pi3, RFlink, PiZigate, Yeelight, klikaanklikuit, Kodi, harmony hub, Zwave, ThermoSmart, XiaomiGateway (Aqara), Google home hub, roomba,
- remb0
Very nice!
I hope you will work on: updating the firmware like rfxcom, and show version number in domoticz.
It would be a lot easiers for me when I helping out my friends and brothers.
- Stuntteam
It is on the todo list
- jumbotroll
Great work!
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Jumbotroll
- Domoticz version: 2024.7
That's a lot of work done - thank you!
Regarding the roadmap, when can we expect Smartwares 433 thermostat valve and Somfy devices to work with the RFLink? I can't see them on the list yet, or are they present with a different name?
Could someone answer the following questions: Is the smartwares 433 thermostat valve supported ? If not, when will this become available ? If yes (which i hope) how can i add this to domoticz? Im (ofcourse) using RFlink with domoticz and raspberry Pi.
Thanks for all the work!
- Stuntteam
New firmware available here: https://sourceforge.net/projects/rflink ... t/download
Changelog:
R37:
- Added: RTS transmit
- Added: ProMax 75.0006.14 (Sold at Action)
- Added: Novatys wall switches
- Added: Perel 4 channel switch set
- Added: Atlantic MD-210R
- Fixed: KD101 detected
- Fixed: GlobalTronics GT-WT-01, GT-WT-02
- Fixed: Alecto V4
- Fixed: Silvercrest switches
- Fixed: UPM/Esic negative temperature values
- Fixed: Oregon data processing speed improvement
- Fixed: Oregon V2 data processing and crc checks
- Fixed: Oregon RTGN318
- Fixed: Oregon wind speed
- Fixed: Humidity for BTHR918, BTHGN129, etc.
- Fixed: filtering out invalid packets for BTHR918, BTHGN129, etc.
- Fixed: Chacon remote control
Changelog:
R37:
- Fixed: Alecto V4
Thank you very much to all who worked on Domoticz and RFLink : Incredible work you've done !
I have tested r37 and cannot make my somfy roller shutter to work.
Here is my log when I try to pair the shutter with RFlink :
20;2E;DEBUG;Pulses=92;Pulses(uSec)=0,480,2430,2520,4740,1230,1170,1200,1170,570,540,570,540,600,510,570,510,1230,510,570,510,600,1170,1260,1140,1230,510,570,510,600,510,600,510,600,510,600,1170,600,480,600,510,1230,510,600,510,600,480,630,1140,600,510,600,480,1260,1140,600,480,600,480,600,480,600,480,600,480,1260,1140,600,510,1260,1140,630,480,1260,480,600,480,600,480,600,480,600,480,600,1140,1260,1140,1260,1140,1260,1140,6990;
10;rfdebug=off;
20;2F;RFDEBUG=OFF;
20;30;RTS;ID=e69b35;SWITCH=01;CMD=DOWN;
10;RTS;e69b35;0;UP;
20;31;CMD UNKNOWN;
In blue what I typed.
Thank you for your feedback,
Alex
Edit : it works now, right command was 10;RTS;e69b35;1;UP;
10;rfdebug=off;
20;2F;RFDEBUG=OFF;
10;RTS;e69b35;0;UP;
20;31;CMD UNKNOWN;
Alex
- Stuntteam
Re: New RFLink firmware available (R38)
On the previously mentioned link:
R38:
Note: Elmes changed into Keyloq you might have to re-learn the device..
- New Device: Initial NodoNRF sensor receive support (2.4ghz) (Thanks: Martinus)
- New Device: Nodo 3.8 slave support
- New Device: Catching of anti-tampering for Atlantic sensors
- New Device: Oregon, extra checks for out of range values
- New Device: Tunex MF-0211 temperature sensor
- New Device: Alecto V3 Rain - Alternative version of WS1200
- New Device: Byron SX21
- New Device: MC145026 based sensors
- New Device: FunkBus remote control support (Insta/Berker/Gira/Jung) (receive only) (Thanks: D.)
- New Device: Kingpin motor controls
- New Device: Livolo
- New Device: Koch remote controls
- New Device: Additional X10 protocol devices
- New Device: Forest "Touch Sense Motors" Curtain control (Thanks: JPe)
- New Device: Faher motor controller DC305, DC307
- New Device: Biltema 84056 temperature and humidity sensor
- New Device: Logipark
- New Device: Friedland EVO doorbell Decor ED1/ED3 (receive only)
- New Device: Friedland DC4 PIR
- New Device: Lobeco door sensors
- New Device: Hadex T093, WH5029
- New Device: FineOffset Temperature & Humidity sensors
- New Device: XT200 temperature sensor
- New Device: Conrad RSL blind controller 640579
- New Device: Smartwares SH5-TDR-A / SHS 5300 Heating Controller / Radiator Valve (Initial support)
- New Device: BFT port opener remotes (Thanks: CS.)
- New Device: Etekcity ZAP
- Added: Oregon, extra checks for out of range values
- Fixed: Oregon Rain sensors (PCR800 and others) (Thanks: D.)
- Fixed: Oregon humidity
- Fixed: Esic WT450H detection
- Fixed: Alecto V1 wind speed values
- Fixed: Alecto V3 Rain values and added battery level support (Thanks: D.)
- Fixed: EverFlourish EMW203T detection
- Fixed: Xiron/Aok humidity
- Fixed: Added more range checks on Aster protocol
- Fixed: Optimized Conrad RSl transmit function
- Fixed: Additional checks on Keeloq protocol
- Fixed: Additional checks on Chuango protocol
- Fixed: Improved EV1527 / Chuango recognition (some issues left)
- Fixed: Added support for the ProMax master buttons
- Fixed: Improved ProMax signal detection
- Fixed: Some changes to X10 command parsing (Thanks: JPe)
- Fixed: RTS increased broadcast time
- Fixed: Ikea Koppla transmit bug
- Fixed: Ikea Koppla dimming issue
- Changed: Created a seperate Novatys plugin
- Changed: Smoke detectors now respond as a switch as well
- Changed: Corrected Elmes label into Keyloq label
- Changed: Splitted the WS1100/WS1200 plugin to improve compatibility
- Changed: Improved WS1200 signal handling
- Changed: Improved incoming command parsing
- Changed: Big speed-up for plugin 1 converted packets
- Changed: Regrouped plugins so new ones can be added more easily
Additional things in progress...
R38:
Is it just me or is sourceforge down or something? Received my rflink today and wanted to play with it but cant seems to find the firmware? Should be here right? https://sourceforge.net/projects/rflink/files/
- jumbotroll
It's down here to, but you can get the latest here: https://drive.google.com/open?id=0BwEYW ... m1fbklFd3c
http://www.nemcon.nl/blog2/2015/07/bb
Jumbotroll
Jumbotroll
Ah didn't see that page, thank youjumbotroll wrote:It's down here to, but you can get the latest here: https://drive.google.com/open?id=0BwEYW ... m1fbklFd3c
