As I was updating the whole setup, I now have the OTGW connected to the RasPi with Domoticz via USB, otmonitor running on the RasPi, and selected OTGW USB as hardware in Domoticz.
Although I am able to get all devices in, they are updated very poorly. If you look at the logscreen, you see that it sometime gets the proper data in (top), but afterwards gets an array of numbers (lower part), which appear to be incomplete each time.
Any idea what is causing this, and how to solve.
I tried to put an USB hub inbetween (read in a different post), but this didnt have any effect.
2016-01-12 22:10:01.825 (OTGW USB) Temp (CV Control Setpoint)
2016-01-12 22:10:01.829 (OTGW USB) General/Percentage (CV Max Relative Modulation Level)
2016-01-12 22:10:01.832 (OTGW USB) Thermostat (CV Room Setpoint)
2016-01-12 22:10:01.836 (OTGW USB) General/Percentage (CV Rel. modulation level)
2016-01-12 22:10:01.840 (OTGW USB) General/Pressure (CV Water Pressure)
2016-01-12 22:10:01.843 (OTGW USB) Temp (CV Room Temperature)
2016-01-12 22:10:01.847 (OTGW USB) Temp (CV Boiler Water Temperature)
2016-01-12 22:10:01.856 (OTGW USB) Temp (DHW Temperature)
2016-01-12 22:10:01.860 (OTGW USB) Temp (CV Outside Temperature)
2016-01-12 22:10:01.864 (OTGW USB) Temp (CV Return Water Temperature)
2016-01-12 22:10:01.869 (OTGW USB) Thermostat (CV DHW Setpoint)
2016-01-12 22:10:01.872 (OTGW USB) Thermostat (Max_CH Water Setpoint)
2016-01-12 22:10:09.222 Hardware Monitor: Fetching data (System sensors)
2016-01-12 22:10:31.827 OTGW: 001/000.00,0.00,1.90,20.00,44.00,35.50,0.00,43.50,65/35,80/20,0.00,0.00,0,0,0,0,0,0,0,0
2016-01-12 22:10:39.288 Hardware Monitor: Fetching data (System sensors)
2016-01-12 22:11:01.829 OTGW: 01/00000,0.00,1.90,20.00,43.50,35.50,0.00,43.50,65/35,80/20,0.00,0.00,0,0,0,0,0,0,0,0
2016-01-12 22:11:09.355 Hardware Monitor: Fetching data (System sensors)
2016-01-12 22:11:31.832 OTGW: 01/00000001,100.00,0/0,20.00,0.00,1.90,20.00,43.00,35.50,0.00,42.50,65/35,80/20,0.00,0.00,0,0,0,0,0,0,0,0
2016-01-12 22:11:39.421 Hardware Monitor: Fetching data (System sensors)
2016-01-12 22:12:01.836 OTGW: 01/00000000,35.50,0.00,42.50,65/35,80/20,0.00,0.00,0,0,0,0,0,0,0,0
2016-01-12 22:12:09.487 Hardware Monitor: Fetching data (System sensors)
2016-01-12 22:12:31.839 OTGW: 01/00000001,100.00,0/0,20.00,0.00,1.90,20.00,42.50,35.50,0.00,42.50,65/35,80/20,0.00,0.00,0,0,0,0,0,0,0,0
2016-01-12 22:12:39.553 Hardware Monitor: Fetching data (System sensors)
2016-01-12 22:13:01.842 OTGW: 01/00020.00,42.50,35.50,0.00,42.00,65/35,80/20,0.00,0.00,0,0,0,0,0,0,0,0
2016-01-12 22:13:09.617 Hardware Monitor: Fetching data (System sensors)
2016-01-12 22:13:31.845 OTGW: 001/000100.00,0/0,20.00,0.00,1.70,20.00,42.00,35.50,0.00,42.00,65/35,80/20,0.00,0.00,0,0,0,0,0,0,0,0
2016-01-12 22:13:39.682 Hardware Monitor: Fetching data (System sensors)
2016-01-12 22:14:01.847 OTGW: 01/0000.00,1.700,0.00,42.00,65/35,0/20,0.00.00,0,0,00,0,0,0,0
2016-01-12 22:14:09.747 Hardware Monitor: Fetching data (System sensors)
2016-01-12 22:14:31.850 OTGW: 01/.00,1.70,20.00,42.00,35.00,0.00,42.00,65/35,80/20,0.00,0.00,0,0,0,0,0,0,0,0
