I connectet some DS18B20 temperature sensors to the Raspi GPIO port and it´s working fine.
But when I disconnect the dataline, it`s not recognized by Domoticz.
Is there a possibility that Domoticz responds to a missing sensor?
Best Regards
@MosWare
How can I detect a missing DS18B20
Moderators: fantom, leecollings
marin849
- Domoticz version: 2.4xxx
Re: How can I detect a missing DS18B20
When a sensor hasn't been updated in X minutes it will we marked red in Domoticz. You can change the timeout in settings-other-timout for sensor.
@MosWare
- Domoticz version: v2.4031
Thank you for your answer.
It is right, that the value is marked red, but the value didn´t change.
How can I set a switch (for example an alarm lamp) while
Sensor communication is lost?
Best regards
@MosWare
Best regards
@MosWare
alfred_j_kwak
- Domoticz version: 2.3530
Make Lua script and monitor lastupdate. There is example on wiki how to monitor garage door.
@MosWare
Hmm, but on loss of communication freezes the value.
There is no difference between a freeze value an a real stable value.
I think this should be realized by Domoticz, without the need of writing a LUA script for this elementary function.
When communication lost, Domoticz could set the value to -1000 °C. So it would be very easy to implement for anyone.
Or, is there a way to request a sensor time out?
Best regards
@MosWare
Best regards
@MosWare
marin849
There is no need to use false values to detect a missing sensor. That would also mess upp the temperature logs.
The lastupdate value tells you when the sensor was last updated.
So you can make a LUA-script that reacts when a sensor has not been updated for 15 minutes for example.
Also, Domoticz colors sensors in read when they have not been updated within a time that you can select in settings.
Toulon7559
- Domoticz version: <2025
My own 'lessons learned' for a disconnected DS18B20: see http://www.domoticz.com/forum/viewtopic ... 948#p54271
