AEOTEC Multisensor 6 sleeping slave even on USB power?
rasper
Domoticz version: 2022.2
Post by rasper »
I am using a AEOTEC Multisensor 6 GEN5 connected through USB power. However in Domoticz it keeps saying me that this node is a "sleeping slave", while my other powered zwave nodes say they are "always on slaves":
Node Id     Basic Type                                              Generic Type                         Product
1 *LB         Static Controller	                              Static PC Controller               Aeotec Z-Stick Gen5
2 LBR+      Z-Wave+ node Reporting Sleeping Slave   Home Security Sensor            Aeotec MultiSensor 6
3 LBR+      Z-Wave+ node Always On Slave	              Siren                                    Aeotec DSD31 Siren Gen5
Is this normal? I would expect the USB powered Multisensor is also an always on slave. I now suspect it is not serving as a routing node. Can I change this and/or can I check that it is in fact routing?
gizmocuz
Re: AEOTEC Multisensor 6 sleeping slave even on USB power?
Post by gizmocuz »
You could compile openzwave yourself, and also the control panel, and check if this also displays it is a sleeping device
If it also displays this, it is
maybe you have to exclude/include it again after putting it on power ?
I wont expect that this node will route traffic
rasper
Post by rasper »
Ok, thanks for the tip. I have never had this device on batteries, so when including it was on power. I will go for the easy way to rearrange my sirene device to another location to recover a dead node (the source of the investigation).
