How to start with RFXTRX433E with Windows?
Posted: Sunday 10 January 2016 17:46
by Johndomo
I am completely new with Domoticz and just bought a set of the RFXTRX433 transceiver, together with a Rasberry.
As I am completely new with this hobby, I thought it would be wise to start simple and just plug the transceiver into my USB port in my Windows 10 laptop, so without using the Rasberry yet.
I connected the Transceiver to the USB port and opened Domoticz. In the Hardware I could add the Transceiver without a problem, but if I then go to the Device screen I get an empty list? What do I do wrong?
Re: How to start with RFXTRX433E with Windows?
Posted: Sunday 10 January 2016 19:05
by Westcott
Hi Johndomo,
It's quite possible that you have done nothing wrong!
Do you have any RFXtrx433e compatible devices?
If so, have you used 'Set Mode' to enable only these device types (and AC)?
Posted: Sunday 10 January 2016 20:57
by Johndomo
Hi Westcott,
Thank you for your quick help!
Yes, I have compatible devices, but no, I didn't use the Set Mode option. So that's the first error....
But now I try. I get a screen in which I can select the device types, where I clicked the button 'Default' to have a selection of device types.
(I think I need AC for KlikaanKlikuit (to start with) but am not sure either).
Then I click the Set Mode button, after which the previous screen shows again. But the list of devices is still empty....
When I go back to the Set Mode screen, all selections are gone again... ?
I've also a button 'Upgrade firmware', but nothing seems to happen if I click that one..
Hope you can help me again?
John
Posted: Sunday 10 January 2016 21:54
by Westcott
Hello again,
Have you operated the KlikaanKlikuit device?
E.g. pressed the doorbell?
The log will show which protocols are dis/enabled, and any devices that have transmitted and been received by your RFXtrx433e
I got new firmware, and RFXmngr from the RFXcom website.
To use RFXmgr, first disable RFXCOM in Setup/Hardware.
Posted: Sunday 10 January 2016 22:10
by Johndomo
Thanks again.
I will take a look at this program and see if it will help me.
For now, I just copied the log, see below.
Maybe it helps...
2016-01-10 21:26:48.154 Domoticz V2.4078 (c)2012-2016 GizMoCuz
2016-01-10 21:26:48.154 Build Hash: 7f07293, Date: 2016-01-10 08:33:58
2016-01-10 21:26:48.154 Startup delay... waiting 10 seconds...
2016-01-10 21:26:59.935 Active notification subsystems: http (1/10)
2016-01-10 21:27:01.201 Webserver(HTTP) started on port: 8080
2016-01-10 21:27:01.482 Webserver(SSL) started on port: 443
2016-01-10 21:27:01.498 Proxymanager started.
2016-01-10 21:27:01.763 Starting shared server on: :::6144
2016-01-10 21:27:01.794 RxQueue: queue worker started...
2016-01-10 21:27:02.201 TCPServer: shared server started...
2016-01-10 21:27:03.935 EventSystem: reset all events...
2016-01-10 21:27:03.951 EventSystem: reset all device statuses...
2016-01-10 21:27:03.966 EventSystem: Started
2016-01-10 21:27:05.107 RFXCOM: Using serial port: COM1
2016-01-10 21:27:15.060 Incoming connection from: 127.0.0.1
subtype = Interface Command
Sequence nbr = 3
set configuration of the interface
2016-01-10 21:30:10.528 RFXCOM: Serial Worker stopped...
2016-01-10 21:30:11.586 RFXCOM: Using serial port: COM1
2016-01-10 21:30:19.529 RFXCOM: Serial Worker stopped...
2016-01-10 21:30:20.588 RFXCOM: Using serial port: COM1
Sequence nbr = 3
Sequence nbr = 5
Sequence nbr = 7
Sequence nbr = 9
Sequence nbr = 11
Posted: Monday 11 January 2016 0:10
by Westcott
Looks as if it is not started.
So -
Is it really on COM1?
Did you get the special drivers?
Have you tried with RFXmngr?
Posted: Monday 11 January 2016 12:36
by Johndomo
It detects the Comm port automatically and it changes if I use another USB port, so I think that is will be correct.
But: special drivers?!? No, I didn't install any myself... So?
RFXmngr: I hope to try that this evening...
Posted: Monday 11 January 2016 12:54
by Westcott
The RFXcom page mentions special drivers, and has a link to them.
Posted: Monday 11 January 2016 22:11
by Johndomo
Thank you for your help. Really appreciated!!
This evening I opened Domoticz, without doing anything else, and there were a few switches visible! So it seems to work.
Now I can start playing and find out how it works!
Thanks again.
Posted: Monday 11 January 2016 23:44
by Westcott
Good news!
Perhaps your devices are a bit slow at reporting...
