lua script On FOR 1 minute
whiteduck
I am running Domoticz v2.3598 on Ubuntu and finding the lua scripting 'On FOR n' doesn't appear to work:
if (devicechanged['LWSwitch'] == 'On') then
commandArray['Lamp']='On FOR 1'
I wondered if this was seconds and On FOR 60 doesn't work either.
Plus I tried " instead of ' just in case it is fussy.
Any clues?
Thanks a lot
Ian
Any clues?
Thanks a lot
Ian
Domoticz on Ubuntu 16.04 LTS VM
RFXCom USB transceiver
Aeon Labs V2 USB (Zwave)
Various HomeEasy, Oregon devices and sensors. Now using Z-Wave Fibaro FGMS-001, TKB TZ88Es
TP-Link IP310 Cameras
jmleglise
- Domoticz version: 2022.1
Re: lua script On FOR 1 minute
The wiki http://www.domoticz.com/wiki/LUA_commands said "FOR" is in minutes when the "AFTER" is in seconds.
a workaround may be to use "AFTER" ?
commandArray[1]={['Relay1']='On'}
commandArray[2]={['Relay1']='Off AFTER 3'}
return commandArrayMy script : https://github.com/jmleglise
RFXTRX433E: Blind Somfy RTS, Portal Somfy Evolvia, chacon IO, Oregon, PIR sensor PT2262
My Last project : Location de vacances a Ouistreham vue mer
KMTronic USB relay
Chinese Z-WAVE: Neo CoolCam
KMTronic USB relay
jmleglise
On second thought, personally I won't be confident with the "FOR" instruction because I don't know How it was designed in Domoticz , (consider that for working, the "on FOR" must assume that Domoticz knows the inverse state of each type of device (open / close, on/off...) For example if you send 2x ON command. The second last state is ON or OFF ?)
So I will really use AFTER with a little more logic :
if device changed then
if device value ==ON then send command OFF after XX seconds
(else nothing to do because the device value == off)
KMTronic USB relay
KMTronic USB relay
whiteduck
Thanks a lot - I tried Off AFTER 7 seconds and it ignored it. I haven't put the device current state logic in yet but tried this from a known state.
Perhaps there is something wrong with the lua installation I have since I am running domoticz (from make file) on Ubuntu. The lua release is 5.2.2 as found in $HOME/domoticz/lua
Best regards and thanks again
Ian
commandArray['Lamp']='On'
commandArray['Lamp']='Off AFTER 7'
endBest regards and thanks again
Ian
- jvdz
- Domoticz version: 4.107
It will ignore one as you are overriding the table entry "lamp" when you do it that way.It should look like this:
Jos
commandArray[1]={['Lamp']='On'}
commandArray[2]={['Lamp']='Off AFTER 7'}
end-
whiteduck
Thanks Jos.
I tried that and it's still not working - pointing towards an lua issue perhaps...
- nayr
- Domoticz version: github
There is more than one way to skin a cat, its more work but you can try a timer script as a work around.. I dont use the FOR and AFTER statements, I use timer scripts to cleanup after me, like so:
script_device_lwswitch.lua
script_time_lamp.lua
All my lighting has scripts like this, but with longer timeouts and without the user-variable logic.. just so people dont leave lights on since I have not got around to installing motion sensors yet. (closets/laundry rooms get like 10mins, bedrooms an hour, kitchen and work areas get several hours)
commandArray['Variable:lamptriggered'] = tostring(1)
endCode: Select all
function timedifference (s)
year = string.sub(s, 1, 4)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
t1 = os.time()
return difference
if (otherdevices['Lamp'] == 'On') and (timedifference(otherdevices_lastupdate['Lamp']) >= 420) and (uservariables['lamptriggered'] == 1) then
commandArray['Lamp']='Off'
commandArray['Variable:lamptriggered'] = tostring(0)
print("Lamp was triggered by an event more than 7mins ago, time to turn it off.")
- jvdz
Any more details on the "not working" bit?whiteduck wrote:Thanks Jos.
Do you see anything in the domoticz log?
Maybe add some print() statements in the lua script to see if it gets fired and inside the "if" to see if it is true.
The output should also show up in the log.
Jos
whiteduck
Nayr - many thanks - nice alternative solution!
Jos - yeah sorry I was a bit vague - I added a print inside the if then but it doesn't get into the log file however the command is firing as seen in the log and by the fact the light comes on - it just doesn't go off after 30, 7 or any time combination
2016-01-10 22:32:18.483 EventSystem: Script event triggered: /root/domoticz/scripts/lua/script_device_lwrf2.lua
2016-01-10 22:32:18.478 (RFXCOM) Lighting 5 (LWSwitch2)
2016-01-10 22:32:19.161 OpenZWave: Domoticz has send a Switch command! NodeID: 10 (0x0a)Code: Select all
print('Lamp On')
commandArray[2]={['Lamp']='Off AFTER 30'}
endDomoticz on Ubuntu 16.04 LTS VM
- jvdz
Did you put the script in the On or Off action field of the switch in stead of storing it in domoticz/scripts/lua and naming it script_device_abc.lua?
Jos
Jos
gertlind1
I tested this with a motion sensor.
Works perfectly for me, light goes off after 1 minute.
Im on version V2.4123r
if (devicechanged['Rörelse'] == 'On' and otherdevices['Hörnbord'] == 'Off') then
commandArray['Hörnbord']='On FOR 1'
Gert
Gert
whiteduck
Thanks Gert
Jos - no I have it in the lua directory… could this be the problem?
- nayr
yes, it has to be in the scripts/lua folder with a specific filename to be called, if its not, ~/domoticz/scripts/lua/script_device_*.lua then its never going to get executed.
the lua folder @ ~/domoticz/lua is a source path, not a script path.
whiteduck
Thanks Nayr - I was replying to Jos asking:
It's getting executed - the issue is the FOR command doesn't appear to work
whiteduck
Everyone,
I realised I was being a bit of a muppet - really sorry - I had two very similar lua scripts and two similar LWRF switches - I was changing the wrong script!!! Thanks a lot for your help… now I am off to hide for a while.
- nayr
Plebkac is the number one cause of issues here it seems
Glad you got it figured out, editing a file you think is another file can become quite maddening.. I feel for yeh.
whiteduck
Time to merge the scripts since they control the same lamp!
Sorry to waste peoples time!
Welsyntoffie
My time was not wasted reading this post. This code snippet helped me to solve my problem.whiteduck wrote: Saturday 16 January 2016 21:24 Time to merge the scripts since they control the same lamp!
