Everspring AN181-2 On/Off Metering
Posted: Wednesday 06 January 2016 17:12
I'm staring with domoticz.
I have a windows install an using a Z stick gen 5.
I got the Everspring AN181-2 (also known as Z-Wave Meter Mini Plug -500 Series )
it is linked to the domoticz and i can switch it on and off.
But i can't select the kwh usage. when i look at the installation is see it is registrated as "Everspring Unknown: type=0004, id=0006".
In the config folder in the everspring filder i don't see a an181.xml.
In openZwave i can see al the parameters and found a description of the device (http://www.pepper1.net/zwavedb/device/688)
is it possible to create my own an181.xml? Do i have to registrate it somewhere ?
Thanks in advance.
Thanks in advance.
