I'm staring with domoticz.
I have a windows install an using a Z stick gen 5.
I got the Everspring AN181-2 (also known as Z-Wave Meter Mini Plug -500 Series )
it is linked to the domoticz and i can switch it on and off.
But i can't select the kwh usage. when i look at the installation is see it is registrated as "Everspring Unknown: type=0004, id=0006".
In the config folder in the everspring filder i don't see a an181.xml.
In openZwave i can see al the parameters and found a description of the device (http://www.pepper1.net/zwavedb/device/688)
is it possible to create my own an181.xml? Do i have to registrate it somewhere ?
Thanks in advance.
Everspring AN181-2 On/Off Metering
- bbqkees
- Domoticz version: 4.1x
Re: Everspring AN181-2 On/Off Metering
What you can do is copy the config file from this one:
https://github.com/OpenZWave/open-zwave ... /an180.xml
And then try to edit the parameters found on the pepper1 website into this config.
Then follow the instruction on the following page how to test this in your setup and if it works then send the file to OpenZWave so they can implement it.
https://github.com/OpenZWave/open-zwave ... ng-Devices
Dennux
- Domoticz version: V2.4028
Thanks for the reply .
i have created the xml file and it works fine now.
niceandeasy
- Domoticz version: 3.8153
Hi, Dennux,Dennux wrote:i have created the xml file and it works fine now.
I could use your help very much.
Can you please share that XML you created. I also have some Everspring AN181-2.
Such files need to be put in Config\Everspring? Do you need to do something else to get it working, for example, restart Domoticz or exclude/include the AN181-2?
Thank you
tieskeer
Hallo Dennux,
I also have an Everspring AN181-2. I need that xml file as well for controlling that device in Domoticz. Can you share it with me too?
