P1 measurement resolution
Posted: Tuesday 05 January 2016 20:50
I'm trying to make my central heating more efficient and to do so I am building a fairly simple logging application which logs the room temperature, the temperature of the radiator and the gas usage. I'm putting this all in a graph which you can see in the attachment.
I'm using a P1 cable to measure the gas usage. If you look at the graph you'll see that the measurement interval for the P1 cable is approximately once every hour. Does anyone know if there is a way to make more samples of the gas usage?
Hope to hear from you,
Jankees
Jankees
