I've also had a go at this, as I actually wanted to import the info and learn python at the same time.
This script is currently missing some error handling, so it's "beta" at best
I run this from cron every 10 minutes.
#!/usr/bin/python3
import argparse
import arrow
import configparser
import logging
import json
import os.path
import urllib.request
import verisure
# Version 0.1
# Author: Jan De Luyck ([email protected])
# This script depends on the verisure module by Per Sandström, which you can find at https://github.com/persandstrom/python-verisure
# Notes: if you want additional sensors to be added, supply me with the output of
# vsure 'user' 'password' overview
# Device config
# Create a dummy hardware device, and add per item you want in Domoticz a Virtual Sensor
# - Temperature + Humidity: smoke detectors
# - Temperature: Siren
# - Switch: door/window locks, ethernet status, arm state
# - Custom Sensor (X Axis: SMS count): SMS
# Add the Verisure identifiers _and_ the device ID's (which you can find on the devices view) to vsure.ini (or your own ini file)
# Please keep the identifiers 'sms count' and 'arm state' for the smscount and alarm state respectively
def parseArgs():
parser = argparse.ArgumentParser(description = 'Import Verisure information into Domoticz', prog='importVerisure.py')
parser.add_argument('-l', '--log', dest='logLevel',type=str, choices=['info', 'warning', 'error', 'debug'], help='Specifies the loglevel to be used')
parser.add_argument('-c', '--config', dest='configFile', default='vsure.ini', type=str, help='Name of the configuration file to use (default: %(default)s')
results = parser.parse_args()
return vars(results)
def parseConfig(configFile):
config = configparser.ConfigParser()
if not os.path.isfile(configFile):
logging.debug('Config file %s does not exist, creating dummy', configFile)
# create a 'new' config file and write it
config['domoticz'] = { 'protocol' : 'http', 'host':'localhost', 'port':'8080'}
config['verisure'] = { 'username':'', 'password':''}
config['global'] = { 'loglevel':'warning', 'timezone':'local'}
config['sensorindex'] = { 'sms count':'XX', 'arm state':'XX', 'AAAA BBBB':'XX'}
with open(configFile, 'w') as file:
config.write(file)
print ("A default (empty) config file was written as %s. Please review and re-run this script.", configFile)
exit (1)
else:
config.read(configFile)
return config
def callDomoticz(URL):
logging.debug ('** Entered CallDomoticz(%s) **', URL)
response = urllib.request.urlopen(URL)
httpOutput = response.read().decode('utf-8')
output = json.loads(httpOutput)
logging.debug ('Output: %s', output)
if output['status'] == 'OK':
if 'result' in output:
returnValue = output['result'][0]
else:
else:
returnValue = -1
logging.error ('ERROR: error occurred querying Domoticz! Full output available in debug.')
return returnValue
def getLastDomoticzUpdatedTimestamp(deviceIndex):
logging.debug ('** Entered getLastDomoticzUpdatedTimestamp(%s) **', deviceIndex)
output = callDomoticz(domoticzUrl + 'type=devices&rid=' + str(deviceIndex))
if output != -1:
returnValue = arrow.get(arrow.get(output['LastUpdate']).naive, config['global']['timezone']).timestamp
else:
logging.debug('Return value: %s', str(returnValue))
return returnValue
def getVerisureInfo(verisureUser, verisurePw):
logging.debug ('** Entered getVerisureInfo(username,password) **')
# Connect to Verisure and get all the data
verisureSession = verisure.Session(verisureUser, verisurePw);
verisureSession.login()
verisureOverview = verisureSession.get_overview()
verisureSession.logout()
logging.debug ('Verisure output:')
logging.debug ('************************')
logging.debug (verisureOverview)
return verisureOverview
def processUpdates(deviceType, sensorIdx, deviceLastUpdated, device):
if 'deviceLabel' not in device:
device['deviceLabel'] = deviceType.upper()
logging.info ('Now processing device %s (sensorIdx %s)', device['deviceLabel'], sensorIdx)
# get last updated time in Domoticz
lastUpdatedDomoticz = getLastDomoticzUpdatedTimestamp(sensorIdx)
if lastUpdatedDomoticz != -1:
logging.info (' - Last Updated in Domoticz: %s', arrow.get(lastUpdatedDomoticz).naive)
# Last updated on Verisure
lastUpdatedVerisure = arrow.get(deviceLastUpdated).timestamp
logging.info (' - Last updated in Verisure: %s', arrow.get(lastUpdatedVerisure).naive)
if lastUpdatedVerisure > lastUpdatedDomoticz:
# Climate devices
if deviceType == 'climate':
logging.info (' - Updating temperature to %s', str(device['temperature']))
requestUrl = 'type=command¶m=udevice&idx=' + sensorIdx + '&nvalue=0&svalue=' + str(device['temperature'])
if 'humidity' in device:
logging.info (' - Updating humidity to %s', str(device['humidity']))
requestUrl += ';' + str(device['humidity']) + ';0'
elif deviceType == 'doorwindow':
# doorWindow locks
if device['state'] == 'CLOSE':
switchState = 'Off'
elif device['state'] == 'OPEN':
switchState = 'On'
logging.info (' - Updating switch status to %s', switchState)
requestUrl = 'type=command¶m=switchlight&idx=' + sensorIdx + '&switchcmd=' + switchState
elif deviceType == 'smscount':
# SMS Count
logging.info (' - Updating SMS count to %s', device['totalSmsCount'])
requestUrl = 'type=command¶m=udevice&idx=' + sensorIdx + '&nvalue=0&svalue=' + str(device['totalSmsCount'])
elif deviceType == 'armstate':
# Alarm Arm status
if device['statusType'] == "DISARMED":
alarmState = 'Off'
else:
alarmState = 'On'
logging.info (' - Updating alarm state to %s', alarmState)
requestUrl = 'type=command¶m=switchlight&idx=' + sensorIdx + '&switchcmd=' + alarmState
elif deviceType == 'ethstate':
# Ethernet status
if device['latestEthernetTestResult'] == True:
ethernetState = 'On'
else:
ethernetState = 'Off'
logging.info (' - Updating ethernet state to %s', ethernetState)
requestUrl = 'type=command¶m=switchlight&idx=' + sensorIdx + '&switchcmd=' + ethernetState
else:
logging.error ('ERROR: Unknown device type!')
requestUrl = None
if requestUrl != None:
output = callDomoticz(domoticzUrl + requestUrl)
if output == -1:
logging.error ('ERROR: Update not sent to Domoticz for device %s!', sensorIdx)
else:
logging.info (' - Update sent successfully to Domoticz')
else:
logging.info (' - Not updating Domoticz')
else:
logging.error ('ERROR: something went wrong querying Domoticz!')
# Execute script
if __name__ == '__main__':
# Parse command line
arguments = parseArgs()
# Read config
config = parseConfig(arguments["configFile"])
# Overwrite loglevel, it can be passed on command line
if arguments['logLevel'] != None:
config['global']['loglevel'] = str(arguments['logLevel'])
# Switch default log level
logging.basicConfig(format='%(asctime)s %(message)s', level=getattr(logging, config['global']['loglevel'].upper()))
# Construct Domoticz url
domoticzUrl = config['domoticz']['protocol'] + '://' + config['domoticz']['host'] + ':' + config['domoticz']['port'] + '/json.htm?'
verisureOverview = getVerisureInfo(config['verisure']['username'], config['verisure']['password'])
# Process climateValues
for device in verisureOverview['climateValues']:
if device['deviceLabel'] in config['sensorindex']:
processUpdates('climate', config['sensorindex'][device['deviceLabel']], device['time'], device)
# Process DoorWindowDevices
for device in verisureOverview['doorWindow']['doorWindowDevice']:
processUpdates('doorwindow', config['sensorindex'][device['deviceLabel']], device['reportTime'], device)
# Process SMS
processUpdates('smscount', config['sensorindex']['sms count'], arrow.now(), verisureOverview)
# Process Alarm State
processUpdates('armstate', config['sensorindex']['arm state'], verisureOverview['armState']['date'], verisureOverview['armState'])
# Process Ethernet State
processUpdates('ethstate', config['sensorindex'][verisureOverview['latestEthernetStatus']['deviceLabel']], verisureOverview['latestEthernetStatus']['testDate'], verisureOverview['latestEthernetStatus'])
Run it for the first time, It'll create a file called vsure.ini, in which you have to fill in the necessary info:
[domoticz]
protocol=http
host=localhost
port=8080
[global]
timezone=local
loglevel=warning
[verisure]
[email protected]
password=superfancypassword
[sensorindex]
AABB CCDD=22
EEFF GGHH=21
IIJJ KKLL=23
MMNN OOPP=28
QQRR SSTT=27
UUVV XXYY=26
ARM STATE=30
SMS COUNT=32
where the identifiers in [sensorindex] are the serial numbers of the different verisure components.
Run the script, It'll push the updates straight into Domoticz. I have no smartplugs, so I haven't added any info for those yet.
