Good morning,
I know I'm not the only Nest field tester on this board and using Domoticz.
Currently, Nest support is using the 'official' Nest web interface http://home.nest.com
Nest Field testers use another website http://home.ft.nest.com
While I'm not allowed to discuss functionality, I can tell that the basics of the Nest official interface and the field test interface are identical.
I recompiled Domoticz on a Raspberry, changing the pointer in Nest.cpp to http://home.ft.nest.com and Nest support for us fieldtesters works perfectly (Thermostat and smoke detectors).
Would it be possible to add a second Nest hardware in Domoticz, called Nest Beta or Nest Fieldtest with only the above mentioned modification?
Recompiling at every update risks breaking the entire setup, and web update would break Nest Fieldtest compatibility at every update.
P.
[680] Nest Fieldtest support
- Domoticz version: 2023.2
Re: [680] Nest Fieldtest support
Any chance of getting the Nest base-url parametrized in Domoticz?
Domoticz on BPI-M2-Pro (compiled on Ubuntu 22.04) and RPI (binary on Raspian 10)
RFXCom, Sonoff Zigbee stick, eBusd Adapter 5, P1, S0, Husdata H60 integration
Zigbee2MQTT AD, MQTT local, AirconWithMe, Ebusd, VolvoRecharge, PSA Car Controller
