I have Domoticz running on a Pi close to my smart meter. Works great. On the top floor I have an Ubuntu system running Domoticz and I have an outdoor mounted SD18B20 sensor connected. It has a serail port ans was used with RRDtool before on the same computer for outdoor temperature logging.
I can not find if it's possible to add this sensor (connected to usbTTY0) to the Domoticz system.
Any help ?
Thanks,
Ben
DS18B20 on serial (usbTTY0) port ?
- gizmocuz
Re: DS18B20 on serial (usbTTY0) port ?
this protocol is not implemented
could you make a mysensor sketch for it? or directly connect it on the gpio ? if you are compiling yourself, make sure wiringpi is build as static library
also make sure that you can read this sensor from the bash terminal
with a direct connection you should be able to add the 1wire hardware to domoticz (if it can find the sensor)
