Lua script executing problem
panomi
Post by panomi »
I'm starting with Domoticz and I've got the following problem executing a lua script. The situation is as follows:
- Got a virtual switch named: 'Yamaha'
- I've got the following lua script(script_device_Yamaha.lua) which resides in the folder: '/volume1/@appstore/domoticz/var/scripts/lua'
if (devicechanged['Yamaha'] == 'Off') then
os.execute ("/volume1/@appstore/domoticz/var/scripts/test.sh")
- The script is supposed to execute the 'test.sh' in folder '/volume1/@appstore/domoticz/var/scripts/'
- The 'test.sh' has got the following code:
#!/bin/sh
python /volume1/@appstore/domoticz/var/scripts/rxv_uit.py
- Both scripts are executable (chmod +x) and if I run the 'test.sh' the script runs and turns my Yamaha receiver on.
Problem lies with the lua script I think. Also I see no logging entries, looks like the lua script is not detected by Domoticz?
If someone can point me in the right direction that would be great!
jvdz
Domoticz version: 4.107
Re: Lua script executing problem
Post by jvdz »
Think you need sh in front of your script:
os.execute ("sh /volume1/@appstore/domoticz/var/scripts/test.sh")
Jos
panomi
Post by panomi »
jvdz wrote:Think you need sh in front of your script:
Jos
Tried that but no luck. Log shows:
2016-01-03 15:36:18.348 (Dummy Control) Lighting 2 (Yamaha)
2016-01-03 15:36:22.727 (Dummy Control) Lighting 2 (Yamaha)
I think I should get something like below but that isn't the case:
 EventSystem: Script event triggered: ....
jvdz
Post by jvdz »
panomi wrote: I think I should get something like below but that isn't the case:
You will only get that notification when you add the script to the Device Setup window in the "On Action" or "Off action" as :
script:///volume1/@appstore/domoticz/var/scripts/test.sh
Jos
panomi
Post by panomi »
Ok. If you don't fill out the On or Off action and you use a script in the lua folder this is automatically called, correct?
In the mean time still trying. If I add an escape character before ("\sh /") then the EventSystem comes up with an error which means the script is executed but the .sh file is not :).
EventSystem: .../local/domoticz/var/scripts/lua/script_device_Yamaha.lua:6: invalid escape sequence near '\s'
panomi
Post by panomi »
Just checking, if I execute command LUA on my synology I get : -ash: lua: not found.
Do I need to install LUA libraries or are these included in Domoticz installation?
nayr
Domoticz version: github
Post by nayr »
why dont you execute the python script directly? whats the point of this shell script that executes another script?
panomi
Post by panomi »
True, the problem is, I can't execute anything. Not with On / Off action and .sh or python. The scripts are all functional but nog through Domoticz. Files have execute rights. I'm confused.
nayr
Post by nayr »
your paths are pretty unique, I presume thats part of the package setup for your nas.. maby something got messed up there.
I had issue with an update broke my scripts, turns out they changed backend so relative paths worked and I had to add an extra / infront for the full path, ie: script:///path/to/script.sh worked but script://path/to/script.sh failed... might give full path a try with the 3x slashes
nayr
Post by nayr »
also for debugging add some console logging to your lua to see if its really firing off or not.
print("Executing external script to turn off receiver.")
panomi
Post by panomi »
Ik heb het probleem als volgt opgelost:
Een RPi2 gepakt en hierop Domoticz geïnstalleerd. Scripts werken direct.
Ik weet dus nog steeds niet waarom ze het op de Synology niet doen, maar kost teveel tijd om uit te zoeken.
