MySensors gw.request()
HarryDutch
Post by HarryDutch »
I'm trying to find out what's possible and what's not with Domoticz and MySensors. I have a simple sketch that's writing a value to 2 sensors (S_BINARY and S_TEMP). So far so good. But when I want to read these values back by using gw.request() only gw.request(CHILD_ID_STATUS, V_STATUS,0) seems to work. I never get a value back when I use gw.request(CHILD_ID_TEMP, V_TEMP,0). This is the sketch:
#include <SPI.h>
#include <MySensor.h>
#define CHILD_ID_STATUS 0
#define CHILD_ID_TEMP   1
MySensor gw;
MyMessage statusmsg(CHILD_ID_STATUS, V_STATUS);
MyMessage tempmsg(CHILD_ID_TEMP, V_TEMP);
void setup() {
  gw.begin(incomingMessage);
  gw.sendSketchInfo("TEST01","1.0");
  gw.present(CHILD_ID_STATUS, S_BINARY);
  gw.present(CHILD_ID_TEMP, S_TEMP);
  pinMode(2, INPUT_PULLUP);//interrupt = 0;
void loop() {
  gw.process();
  gw.send(statusmsg.set(0));
  gw.send(tempmsg.set(45));
  gw.request(CHILD_ID_TEMP, V_TEMP,0);
  gw.request(CHILD_ID_STATUS, V_STATUS,0);
  gw.wait(5000);
  gw.sleep(0,FALLING);
void incomingMessage(const MyMessage &message) {
  if (message.type == V_TEMP) {
    Serial.println("TEMP");
  if (message.type == V_STATUS) {
    Serial.println("STATUS");
This is the output from the serial monitor:
send: 14-14-0-0 s=0,c=1,t=2,pt=2,l=2,sg=0,st=ok:0
send: 14-14-0-0 s=1,c=1,t=0,pt=2,l=2,sg=0,st=ok:45
send: 14-14-0-0 s=1,c=2,t=0,pt=0,l=0,sg=0,st=ok:
send: 14-14-0-0 s=0,c=2,t=2,pt=0,l=0,sg=0,st=ok:
read: 0-0-14 s=0,c=2,t=2,pt=0,l=1,sg=0:0
STATUS
I'm sure that I'm missing something, but I have no idea what.
EDIT
Solved it after replacing "V_TEMP" by "V_VAR1". Still don't understand why but it's working now.
gizmocuz
Re: MySensors gw.request() [SOLVED]
Post by gizmocuz »
I was just going to say.... only setting/reading values is supported wth V_VAR1 till V_VAR5
HarryDutch
Using latest beta Domoticz
MySensors 1.5
I still have problems with gw.request(). Started all over again. Removed the MySensors serial gateway. Added a new one and runned this sketch:
#include <SPI.h>
#define ID_VAR1   1
#define ID_STATUS 2
MySensor gw;
MyMessage msgvar1(ID_VAR1, V_TEMP);
MyMessage msgstatus(ID_STATUS, V_STATUS);
void setup() {
  gw.sendSketchInfo("TEST02","2.0");
  gw.present(ID_VAR1, S_TEMP);
  gw.present(ID_STATUS, S_BINARY);
void loop() {
  gw.process();
  gw.send(msgvar1.set(40));
  gw.wait(2000);
  gw.send(msgstatus.set(1));
  gw.wait(2000);
  gw.request(ID_VAR1, V_VAR1);
  gw.wait(2000);
  gw.request(ID_STATUS, V_STATUS);
  gw.wait(5000);
  if (message.type == V_VAR1) {
    Serial.print("TEMP = ");Serial.println(message.getInt());
    Serial.print("STATUS = ");Serial.println(message.getInt());
The value of S_TEMP is set to 40 and the value of S_BINARY is set to 1 ("on"). They both show the right value in Domoticz and this is the serial ouput from the node:
send: 5-5-0-0 s=1,c=1,t=0,pt=2,l=2,sg=0,st=ok:40
send: 5-5-0-0 s=2,c=1,t=2,pt=2,l=2,sg=0,st=ok:1
send: 5-5-0-0 s=1,c=2,t=24,pt=0,l=0,sg=0,st=ok:
read: 0-0-5 s=1,c=2,t=24,pt=0,l=2,sg=0:40
TEMP = 40
send: 5-5-0-0 s=2,c=2,t=2,pt=0,l=0,sg=0,st=ok:
read: 0-0-5 s=2,c=2,t=2,pt=0,l=1,sg=0:1
STATUS = 1
In the sketch I then changed the value of V_TEMP from 1 to 0 ("off") and V_VAR1 from 40 to 60 and runned the sketch again. In Domoticz I can see that both values have changed but when I checked the serial output I get this:
send: 5-5-0-0 s=1,c=1,t=0,pt=2,l=2,sg=0,st=ok:60
send: 5-5-0-0 s=2,c=1,t=2,pt=2,l=2,sg=0,st=ok:0
TEMP = 40
read: 0-0-5 s=2,c=2,t=2,pt=0,l=1,sg=0:0
STATUS = 0
The value of STATUS has changed but the value of TEMP has not. I have restarted the controller (Pi) but the value of TEMP keeps on showing 40 instead of 60. Any idea?
gizmocuz
Post by gizmocuz »
You can only request V_VAR messages, and in the top of your code i see you try to request a V_TEMP
this will not work, if you change it to
MyMessage msgvar1(ID_VAR1, V_VAR1);
it should
HarryDutch
Ok, it's working now. Thanks.
Flopp
Post by Flopp »
gizmocuz wrote:You can only request V_VAR messages, and in the top of your code i see you try to request a V_TEMP
it should
How can I change VAR1 in Domoticz interface?
I don't want to open Domoticz.db.
gizmocuz
Post by gizmocuz »
you can not
from your mysensors node, you can set a V_VAR
and you can read a V_VAR from your mysensors node
can be used to store a counter value for example (see the watermeter sketch)
Flopp
Post by Flopp »
gizmocuz wrote:you can not
Thank you
