slimme meter no more hourly updates
maxtrash
Post by maxtrash »
i've been logging my gas for more than a year now without problems. Electricity is updated every 5 seconds or so and the gas meter was updated every hour.
For some reason the gas meter is not updated anymore, still giving the same reading of last night 0:00.
Can anyone check if it's the same for you? I'm with Enexis and have an Iskra meter.
JapieG
Domoticz version: 2022.1
Re: slimme meter no more hourly updates
Post by JapieG »
Same here
Iskra ME382
Landis Gyr G350 wireless connected
Update in domoticz just fine, except the valuesfaus the same as it was at 00:00 jan 01.
marcelr
Domoticz version: svn 2470
Post by marcelr »
My stuff still works, but apparently a lot of people have this problem.
From another forum:
http://www.domoticaforum.eu/viewtopic.php?f=71&t=10996
grtz,
marcelr
buxol
Post by buxol »
I've also noticed this today. The digital display on my gasmeter is showing the correct milage, that number is still increasing. But the readout from the P1-telegram shows the last milage from 2015. So Domoticz is working just fine. Don't mess with your setup.
Hans
Domoticz version: all
Post by Hans »
Same issue on my end.
Electra OK (all 4) but Gas reading 0.00. Problem did start with the switch to 2016. Hardware platform: Raspberry 2B. Domoticz version: V2.3530
Additional info:
Just checked my "SlimmemeterPortal" data. For Jan 1, I do see Electra usage but no Gas usage (only temp graph, Gas = 0.0). This could point to a communication problem between Gas and Electra meter. In that case it will be an Enexis problem (network provider).
RichardBokker
Domoticz version: 3.9317
Post by RichardBokker »
Same problem here, no gas readings since 2016..
JacquesMulders
Post by JacquesMulders »
performed readout of the telegrams posted by the meter.
actual metervalue: 1842,xxx m3
P1 telegram ontvangen op: 2016-01-02 20:39:43
Meter fabrikant: IskraEmeco
Meter informatie:
 0. 2. 8 - DSMR versie: 30
96. 1. 1 - Meternummer Elektriciteit:
 1. 8. 1 - Meterstand Elektriciteit levering (T1/Laagtarief): 3148.213 kWh
 1. 8. 2 - Meterstand Elektriciteit levering (T2/Normaaltarief): 2302.277 kWh
 2. 8. 1 - Meterstand Elektriciteit teruglevering (T1/Laagtarief): 1308.444 kWh
 2. 8. 2 - Meterstand Elektriciteit teruglevering (T2/Normaaltarief): 3060.115 kWh
96.14. 0 - Actueel tarief Elektriciteit: 1
 1. 7. 0 - Actueel vermogen Electriciteit levering (+P): 0.450 kW
 2. 7. 0 - Actueel vermogen Electriciteit teruglevering (-P): 0.000 kW
17. 0. 0 - Actuele doorlaatwaarde Elektriciteit: 999.000 kW
96. 3.10 - Actuele schakelaarpositie Elektriciteit: 1
96. 7.21 - Aantal onderbrekingen Elektriciteit: 0
96. 7. 9 - Aantal lange onderbrekingen Elektriciteit: 0
99.97. 0 - Lange onderbrekingen Elektriciteit logboek:
32.32. 0 - Aantal korte spanningsdalingen Elektriciteit in fase 1: 0
52.32. 0 - Aantal korte spanningsdalingen Elektriciteit in fase 2: 0
72.32. 0 - Aantal korte spanningsdalingen Elektriciteit in fase 3: 0
32.36. 0 - Aantal korte spanningsstijgingen Elektriciteit in fase 1: 0
52.36. 0 - Aantal korte spanningsstijgingen Elektriciteit in fase 2: 0
72.36. 0 - Aantal korte spanningsstijgingen Elektriciteit in fase 3: 0
31. 7. 0 - Instantane stroom Elektriciteit in fase 1: 0.000
51. 7. 0 - Instantane stroom Elektriciteit in fase 2: 0.000
71. 7. 0 - Instantane stroom Elektriciteit in fase 3: 0.000
32. 7. 0 - Spanning Elektriciteit in fase 1: 0.000
52. 7. 0 - Spanning Elektriciteit in fase 2: 0.000
72. 7. 0 - Spanning Elektriciteit in fase 3: 0.000
21. 7. 0 - Instantaan vermogen Elektriciteit levering (+P) in fase 1: 0.000
41. 7. 0 - Instantaan vermogen Elektriciteit levering (+P) in fase 2: 0.000
61. 7. 0 - Instantaan vermogen Elektriciteit levering (+P) in fase 3: 0.000
22. 7. 0 - Instantaan vermogen Elektriciteit teruglevering (-P) in fase 1: 0.000
42. 7. 0 - Instantaan vermogen Elektriciteit teruglevering (-P) in fase 2: 0.000
62. 7. 0 - Instantaan vermogen Elektriciteit teruglevering (-P) in fase 3: 0.000
96.13. 1 - Bericht code:
96.13. 0 - Bericht tekst:
MBus Meterkanaal: 1
24. 1. 0 - Productsoort: 3 (Gas)
91. 1. 0 - Meternummer Gas:
24. 3. 0 - Tijdstip meterstand Gas levering: 2016-01-02 20:00:00
24. 3. 0 - Meterstand Gas levering: 1833.847 m3
24. 4. 0 - Actuele kleppositie Gas: 1
Einde P1 telegram
the telegram is sending the wrong data, so domoticz is not faulty here but the meters... delayed millennium bug?!
ThinkPad
Post by ThinkPad »
A first (and maybe to quick) conclusion is that only customers who have Enexis as their 'netbeheerder' seem to be affected.
To find out, a small poll:
Poll: Ik heb problemen met uitlezing slimme meter Tussenstand:
Ook een poll maken? Klik hier
(Poll was also posted on Tweakers.net forum and Domoticaforum.eu)
pimvolkert
Domoticz version: 2020.1
Post by pimvolkert »
It is a known issue for the following meter: ISKRA ME 382 meter DSMR versie 2.2.
The netmanager should solve it.
See: https://forum.eneco.nl/storingen-proble ... ters-10188
Derik
Post by Derik »
pimvolkert wrote:It is a known issue for the following meter: ISKRA ME 382 meter DSMR versie 2.2.
And then you just have a TOON, with monthly fees
Love Domoticz....
Do not use the button, just look for info@domoticz in PayPal... ;)
ThinkPad
Post by ThinkPad »
Love Domoticz....
Please stay ontopic, your post is completely off the subject here :roll:
pimvolkert
Liander is aware of the problem as you can read from this reply I got this morning (via Facebook chat):
Sorry for the Dutch Language...
"Liander is op de hoogte van dit probleem. Wij zijn bezig om dit te controleren en het heeft zeker een hoge prioriteit. Wel wil ik je meegeven dat het ook kan zijn dat jou leverancier zijn soft-hardware nog moet aanpassen. Zodra ik intern binnen krijg dat het opgelost is laat ik het weten."
buxol
Post by buxol »
Bericht namens netbeheerders. 4 jan 2015.
Goedendag,
Met dit bericht willen wij u namens uw netbeheerder informeren over het volgende:
Momenteel ervaren de netbeheerders een storing in de uitlevering van P4-standen bij een deel van de slimme gasmeterpopulatie.
De storing doet zich voor op een groot deel van de gasmeters die gekoppeld zijn aan een Iskra DSMR 2.2+ type 382 Elektra-meter.
Deze elektrameters hebben een serienummer welke begint met KA6P KAL7 ZBBD of ZBEV. Deze elektrameters hebben een blauwe drukknop en zijn zo gemakkelijk voor de klant identificeerbaar.
Gasmeterstanden van betreffende populatie van 2 januari en later kunnen momenteel niet worden geleverd.
De reeds geleverde en te leveren intervalstanden van 1 januari zijn niet correct/compleet (eerste uren gelijkblijvende standen, daarna aangevuld met nulstanden).
De reeds geleverde en te leveren dagstanden en maandstanden van 1 januari zijn wel correct.
Ook op de P1 poort van de E-meter worden geen actuele gasmeterstanden uitgestuurd.
Voor de duidelijkheid:
Elektrameterstanden worden nog gewoon geleverd en ook gasmeterstanden van gasmeters die onder andere typen elektrameters (Kaifa en L&G DSMR 4.x) hangen worden gewoon geleverd.
De netbeheerders zijn met hoogste prioriteit bezig om dit issue te onderzoeken. Er lijkt na de jaarovergang een probleem te zijn ontstaan met het opslaan van gasmeterstanden in dit type Elektrameter.
Zodra er meer nieuws is zullen we u verder informeren.
Onze excuses voor het ontstane ongemak.
https://www.slimmemeterportal.nl/over_smp
joostvanderlinde
Domoticz version: 2023.2
Post by joostvanderlinde »
There is a solution underway to fix the hourly update of the Gas meterreading. The grid operator will deploy a software update to the affected (IkraEmeco) smart meters in the weeks following this saturday.
Check Smartmeterdashboard.nl blog
Domoticz on BPI-M2-Pro (compiled on Ubuntu 22.04) and RPI (binary on Raspian 10)
RFXCom, Sonoff Zigbee stick, eBusd Adapter 5, P1, S0, Husdata H60 integration
Zigbee2MQTT AD, MQTT local, AirconWithMe, Ebusd, VolvoRecharge, PSA Car Controller
D'rMorris
Post by D'rMorris »
joostvanderlinde wrote:There is a solution underway to fix the hourly update of the Gas meterreading. The grid operator will deploy a software update to the affected (IkraEmeco) smart meters in the weeks following this saturday.
Indeed, also check this link (Dutch).
