x10 cm15pro controller
roymassa
how can i read the status of mine Light switches in domoticz. When I switch a Light with a external device. the status in domoticz is not updatede. at the nc console i see the RX transmission
albaga
Re: x10 cm15pro controller
I've tried, but I not been able.
The CM15Pro receive it, but does not domoticz.
In theory, hardware "Mochad CM15Pro bridge with LAN interface", it would be to do it, but I did not know how to create the devices.
If anyone has done it, please, tell it.
JeroenL
- Domoticz version: 2023.2
I have this working as follows:
- CM15 Pro with mochad setup as descriped in the Wiki.
- In hardware you add the Mochad Cm15Pro Lan interface, use local host as address and port 1099.
- RFXCom for the main X10 control
If you now send commands using the RF remote control (for instance), domoticz adds these to the un-used devices list.
Import these, by clicking on the Arrow right of the device list, and make this device a "SLAVE" of the main "MASTER" device.
I am using RFXCom to control my X10 (MASTER) devices.
If the CM15Pro now detects a RF signal or a signal on the powerline, the status in Domoticz changes accordingly. Works like a charm.
Good luck.
Good luck.
franzelare
When you hook the CM15pro up to a windows PC and use the ActiveHome Pro software, do you see the switch commands and can you control the lights?
Clearing the memory of the CM15pro did work for me in the past when domoticz did not get communication with the unit using mochad.
Fresh set of batterys might also help in some cases...
