SRT323 / Secure (ex-Horstmann) - Please implement !
Posted: Wednesday 30 December 2015 14:33
by corx
I bought a SRT323 thermostat, it was recognized like Horstmann/unknown.
3 devices were discovered
- Temperature
- setpoint
- And "thermostat mode " (?)
It is impossible to set a setpoint .
The "thermostat mode" has no associated action
The most important problem is that it is not possible to operate the internal relay via a switch.
You can implement this device in Domoticz please ?
Thanks a lot .
CorX
Re: SRT323 / Secure (ex-Horstmann) - Please implement !
Posted: Wednesday 30 December 2015 16:26
by bbqkees
You are asking on the wrong forum.
Domoticz relies on the OpenZWave library for Z-Wave devices.
There is no config file for your thermostat in OpenZWave.
It needs to be created with the help of all the configuration options this device has.
As there is no real manual on the internet you have to ask the manufacturer.
Armed with all the possible configuration settings you can ask the OpenZWave initiative if someone over there would like to create it.
Or make your own.
Posted: Wednesday 30 December 2015 16:44
by Westcott
It looks identical to one of these - I have two -
Horstmann HRT4-ZW Thermostat Transmitter
Posted: Thursday 31 December 2015 12:06
by bbqkees
Westcott wrote:It looks identical to one of these - I have two -
Might be but it is not recognized as such by OpenZWave.
Posted: Sunday 03 January 2016 18:20
by peterchef
hi, I used a process a bit like the following to include a horstmann thermostat ...
http://www.vesternet.com/resources/appl ... olX_o-cGM8
hope it helps
Posted: Monday 08 August 2016 13:16
by Nomader
Has the srt-323 been supported?
I can find it in openzwave db: http://www.openzwave.com/device-database/0059:0004:0001
does that mean it is supported and will work in domoticz?
SRT323-Mode widget does not update
Posted: Sunday 29 October 2017 9:33
by benp
SRT 323 is supported in domoticz V3.8153 (stable) :
  • You can get temperature
  • You can set temperature setpoint
But mode (heating or Idle) is not working properly. The widget exist in domoticz but is not changing.
Mode is working properly in open zwave.
Any idea on how to link properly with ozw?
