I bought a SRT323 thermostat, it was recognized like Horstmann/unknown.
3 devices were discovered
- Temperature
- setpoint
- And "thermostat mode " (?)
It is impossible to set a setpoint .
The "thermostat mode" has no associated action
The most important problem is that it is not possible to operate the internal relay via a switch.
You can implement this device in Domoticz please ?
Thanks a lot .
CorX
SRT323 / Secure (ex-Horstmann) - Please implement !
- bbqkees
- Domoticz version: 4.1x
Re: SRT323 / Secure (ex-Horstmann) - Please implement !
You are asking on the wrong forum.
Domoticz relies on the OpenZWave library for Z-Wave devices.
There is no config file for your thermostat in OpenZWave.
It needs to be created with the help of all the configuration options this device has.
As there is no real manual on the internet you have to ask the manufacturer.
Armed with all the possible configuration settings you can ask the OpenZWave initiative if someone over there would like to create it.
Or make your own.
Or make your own.
- Westcott
It looks identical to one of these - I have two -
Horstmann HRT4-ZW Thermostat Transmitter
- bbqkees
Might be but it is not recognized as such by OpenZWave.Westcott wrote:It looks identical to one of these - I have two -
peterchef
- Domoticz version: 2024.4
hi, I used a process a bit like the following to include a horstmann thermostat ...
http://www.vesternet.com/resources/appl ... olX_o-cGM8
hope it helps
hope it helps
Windows, Domoticz
Aeotec Z-Stick Gen5, Aeotec Multisensor 6, Horstmann HRT4-ZW Thermostat Transmitter, Horstmann ASR-ZW Thermostat Receiver
Zipato Mini Keypad RFID, Everspring AN157 Plug
Nomader
Has the srt-323 been supported?
I can find it in openzwave db: http://www.openzwave.com/device-database/0059:0004:0001
does that mean it is supported and will work in domoticz?
benp
- Domoticz version: V4.10717
SRT323-Mode widget does not update
SRT 323 is supported in domoticz V3.8153 (stable) :
Mode is working properly in open zwave.
Any idea on how to link properly with ozw?
- You can get temperature
- You can set temperature setpoint
Domoticz V2024.7
