Greenwave powernode 6 and Fibaro FGK-101
assenzuid
Post by assenzuid »
Stange behavior with FGK-101 (door and window sensor) and my Greenwave PowerNode 6 ports.
Out of the blue the FGK-101 (Door/window sensor) is triggering the PowerNode 6 ports to switch off/on port1 when the the door is open or closed where the FGK-101 installed on.
It has works correctly, but now when the door will be opened/ closed port 1 on the PowerNode is switch off or on.
dimmer
Re: Greenwave powernode 6 and Fibaro FGK-101
Post by dimmer »
What helped me a lot is set the debug on verbose and restart domoticz (see Domoticz manual for how to)... Now you are able to see (a few) more details in what's happening in your Domoticz. It's strange that it happens out of the blue...
Can you post the log while reproducing the issue?
I've the greenwave powernode 6 by myself but never have seen this.
Egregius
Domoticz version: v2024.7
Post by Egregius »
Did you change group associations? Or reaction on alarm level?
assenzuid
Post by assenzuid »
For Some reason setting parameter 13. Transmitting the alarm or control frame broadcast mode: was changed from IN1 and IN2 Broadcast inactive to active.
This triggers the power off/on of port 1 at the PowerNode
