Node has failed
bibbi1969
Node has failed
Post by bibbi1969 »
good evening for a few days with my rpi2 z wave v.2.3530 shows me that he lost the connection with my node, I tried to reboot but I risultati.cosa can I do?
Thank you, bye
2015-12-29 16:40:18.523 Domoticz V2.3530 (c)2012-2015 GizMoCuz
2015-12-29 16:40:18.523 Build Hash: 9eef872, Date: 2015-11-01 11:41:18
2015-12-29 16:40:18.523 System: Raspberry Pi
2015-12-29 16:40:18.524 Startup Path: /home/pi/domoticz/
2015-12-29 16:40:18.921 Sunrise: 07:37:00 SunSet:16:44:00
2015-12-29 16:40:18.921 EventSystem: reset all events...
2015-12-29 16:40:18.973 Active notification subsystems: (0/10)
2015-12-29 16:40:19.061 Webserver started on port: 8080
2015-12-29 16:40:19.103 Webserver started on port: 443
2015-12-29 16:40:19.109 Started shared server on: 0.0.0.0
2015-12-29 16:40:21.111 EventSystem: reset all events...
2015-12-29 16:40:21.112 EventSystem: reset all device statuses...
2015-12-29 16:40:21.113 EventSystem: Started
2015-12-29 16:40:21.611 OpenZWave: Starting...
2015-12-29 16:40:21.615 OpenZWave: Version: 1.3-523-gb258e9e
2015-12-29 16:40:21.615 OpenZWave: using config in: /home/pi/domoticz/Config/
2015-12-29 16:40:21.787 OpenZWave: Driver Ready
2015-12-29 16:40:21.790 OpenZWave: Value_Added: Node: 14 (0x0e), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2015-12-29 16:40:21.791 OpenZWave: Value_Added: Node: 14 (0x0e), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 1
2015-12-29 16:40:21.791 OpenZWave: Value_Added: Node: 14 (0x0e), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 1
2015-12-29 16:40:21.791 OpenZWave: Value_Added: Node: 14 (0x0e), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 1
2015-12-29 16:40:21.791 OpenZWave: Value_Added: Node: 14 (0x0e), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
2015-12-29 16:40:21.792 OpenZWave: Value_Added: Node: 14 (0x0e), CommandClass: SWITCH MULTILEVEL, Label: Open, Instance: 1
2015-12-29 16:40:21.792 OpenZWave: Value_Added: Node: 14 (0x0e), CommandClass: SWITCH MULTILEVEL, Label: Close, Instance: 1
2015-12-29 16:40:21.792 OpenZWave: Value_Added: Node: 14 (0x0e), CommandClass: SENSOR MULTILEVEL, Label: Power, Instance: 4
2015-12-29 16:40:21.792 OpenZWave: Value_Added: Node: 14 (0x0e), CommandClass: METER, Label: Energy, Instance: 1
2015-12-29 16:40:21.793 OpenZWave: Value_Added: Node: 14 (0x0e), CommandClass: METER, Label: Power, Instance: 1
2015-12-29 16:40:21.795 OpenZWave: Value_Added: Node: 15 (0x0f), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2015-12-29 16:40:44.712 Incoming connection from: 192.168.0.5
2015-12-29 16:40:58.478 (rpi2) Lighting 2 (tapparella)
2015-12-29 16:40:58.487 (rpi2) Lighting 2 (tapparella)
2015-12-29 16:40:58.491 (rpi2) General/kWh (kWh tapp)
2015-12-29 16:40:58.492 (rpi2) Usage ()
2015-12-29 16:40:58.493 (rpi2) General/kWh (kWh tapp)
2015-12-29 16:40:58.494 (rpi2) Usage ()
2015-12-29 16:40:58.496 OpenZWave: Received Node Dead notification from HomeID: 235736075, NodeID: 14 (0x0e)
2015-12-29 16:41:03.020 OpenZWave: All Nodes queried (Some Dead)
2015-12-29 16:41:03.021 (rpi2) Lighting 2 (luce natale)
2015-12-29 16:41:03.026 OpenZWave: Received Node Dead notification from HomeID: 235736075, NodeID: 15 (0x0f)
2015-12-29 16:41:35.396 Error: OpenZWave: Node has failed (or is not alive), Switch command not sent! (NodeID: 15, 0x0f)
2015-12-29 16:41:42.372 Error: OpenZWave: Node has failed (or is not alive), Switch command not sent! (NodeID: 14, 0x0e)
2015-12-29 16:42:12.679 Incoming connection from: 192.168.0.3
2015-12-29 16:59:49.773 Incoming connection from: 192.168.0.6
