Manually set IDX?
strelniece
Domoticz version: 3.8153
Manually set IDX?
Post by strelniece »
is it possible to change the IDX manually?
Why?
I have sensors via tellstick and want to send the data to Domoticz, via node-red and MQTT. Since the sensors has a one ID in tellstick and another in Domoticz, I have to do a conversion, in node-red-
Of course it would be much easier to change the IDX in Domoticz. Haven't found a straightforward way to do it, does anyone know if it's at all possible?
(Change it in tellstick seems even more impossible...)
gizmocuz
Re: Manually set IDX?
Post by gizmocuz »
You could backup your database from the settings page, then open the database in a editor like 'SQLite Expert Personal Edition'
then change the IDX values in the 'DeviceStatus' table
When doing so, i would also clear all log tables (Meter/Multimeter/....) or change also the IDX value there as well
Depending on the amount of devices, maybe best todo this in the node-red script, making one lookup table, easy to extend later
